I dont have a Neutral Safety Switch.
Old Dec 6, 2005 | 03:10 PM
DontMixWithRice's Avatar
What should I do?
Recently I swapped in an Lt1 for a 3.4l 95.
I bought the entire wiring system for a 94 lt1, but apparently the dash harness is an automatic.
My question is, I know that there's a main connector that goes to the automatic shifter. This connector has 6 wires. 2 for hatch, 2 for reverse lights, and 2 for neutral safety switch.
None of this is working.
Old Dec 6, 2005 | 06:31 PM
rngilliland's Avatar
Re: I dont have a Neutral Safety Switch.
The two thickest wires on the connector should be the ones for the neutral safety switch. If you only have one thick wire try the thick one and the one just below it.
Connect them and see if the car will turn over. If it does then run those wires to the switch on your pedals.
This link has the wire colors.
http://www.afrashteh.com/tranny_pics/T56.htm
RUENUF
Mar 13, 2016 03:37 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
Daluchman1974
Sep 11, 2015 06:12 AM
4586
Aug 18, 2015 07:08 AM
