Proper procedure for AC delete?
Old Aug 3, 2009 | 03:25 PM
MeenZ28's Avatar
I have the delete pully already but i need to know what needs to come out and how to rerout the hoses etc. I know it can't be that hard but I don't what to mess anything up. Is there a walk threw I can use? Thanks in advance.
Old Aug 3, 2009 | 10:36 PM
omgwtfdied's Avatar
keep your air its hot in cali
Old Aug 4, 2009 | 01:01 PM
ulakovic22's Avatar
Are you planning on taking the whole system out? Just start unscrewing everything and taking it out, like you said, it's not rocket science.
Old Aug 4, 2009 | 03:50 PM
94SLUG's Avatar
MAKE SURE YOU EVAC THE SYSTEM FIRST!
Thats all I did, went as far as taking out evap, cond, comp, dryer, lines, and heater core... Looks like this
Old Aug 4, 2009 | 11:09 PM
RalphBoggero's Avatar
how many pounds can you remove deletin the system under the dash? I just delete de A/C compresor and radiator. and put the battery in the trunk. but Im not sure if its a good idea to remove all the system under the dash , what do you think guys ?
Old Aug 5, 2009 | 10:25 AM
94SLUG's Avatar
I removed all of it!!!! Under the dash too, not much for the weight factor...
Old Aug 6, 2009 | 04:03 AM
Procharged94Lt1's Avatar
i ditched the a/c, took about an hour at most- only because its a pain getting the lines and the a/c rad out of there.
I kept the heat though- kinda need it here in NY to extend the days of driving the car...
Car doesn't have to work as hard staying cool now either- even with stock rad without the ac rad in front of it gets much better air flow..
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
War Engine
Aug 28, 2015 06:04 AM
tnmotown
Aug 10, 2015 11:52 PM
