Programming with a Laptop?
Old Feb 17, 2008 | 07:16 PM
Counted Out's Avatar
So I've heard of this being done, but I can't find much information on it. I already have a laptop, so what software would I need?
Also, I have a 93 so it's using the old computer stuff, will that be a problem?
Old Feb 17, 2008 | 07:25 PM
96capricemgr's Avatar
93s have a replacable chip which requires extra hardware to deal with. The 94-5 stuff is cheap and easy to reprogram just hooking to the ALDL port under the dash. The 96+ stuff reprograms from under the dash too but the software to do it is more expensive.
Old Feb 17, 2008 | 07:28 PM
'94 Bad A Z28's Avatar
You have to have chips burned for your '93. so tuning with a laptop is out of the question. At least as it would be on a 94+ car.
Old Feb 17, 2008 | 07:42 PM
That's what I was thinking, thank you.
Old Feb 17, 2008 | 08:29 PM
maybe2fast's Avatar
for a 95 what software is needed?
and hardware
Old Feb 17, 2008 | 09:44 PM
Stl94LT1's Avatar
and hardware
I use Tunercat and an AKM cable, and Datamaster for my data logging.
http://tunercat.com/tnr_desc/do_tc.html
http://www.akmcables.com/ccard.htm
http://www.ttspowersystems.com/DataMaster.html
Old Feb 18, 2008 | 11:51 AM
As far as the 93, look at the systems available from Moates:
http://www.moates.net/index.php?cPath=50
As far as the 95:
You can also scan OBD-I with Andy Whitaker's "FreeScan", and tune 94/95 with LT1_Edit. LI1_Edit can also include pcmcomm scanning software, if you buy it that way:
http://www.andywhittaker.com/ECU/Fre...0/Default.aspx
http://www.carputing.com/
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
MDZ28
11
Sep 24, 2015 09:15 AM
marlar98
Sep 19, 2015 07:53 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
whitehooptie
Aug 10, 2015 07:02 AM
