Problems wiring reverse lockout
Old Apr 4, 2005 | 07:55 PM
speed_demon24's Avatar
I did a T56 swap a few months ago and still haven't gotten the reverse lockout to work like it should. I wired the silinoid into the D6 port and now it stays open all the time, I can go into reverse at any speed now, its never locked out.
Old Apr 5, 2005 | 05:42 AM
slopokrodrigez's Avatar
Re: Problems wiring reverse lockout
Pull the solenoid out and test it with 12V to see that it works.
Old Apr 5, 2005 | 12:30 PM
What would that prove? What I'm trying to say is it doesn't lock me out of reverse at all. I can go into reverse at any speed.
Old Apr 5, 2005 | 01:19 PM
1-bad-z28's Avatar
if power is applied then it will lock you out. He's sayin check to see if the solenoid is bad. If it is then you can go into reverse anytime.
Old Apr 5, 2005 | 04:53 PM
Isn't it when power is supplied to it that it lets you into reverse? When I had the tranny out of the car I couldnt get it into reverse because no power was being supplied to it. And I had the wire on the wronge wire on the PCM before and it would always lock me out of reverse so I don't think the silinoid is bad.
Old Apr 5, 2005 | 07:59 PM
961le's Avatar
what wire did you use to the rev. lockout pigtail out of the a4 harness?
Old Apr 5, 2005 | 08:50 PM
I bought the pigtail from a dealership...
Old Apr 5, 2005 | 08:54 PM
961le's Avatar
i know but what wire are you using to send power through the pigtail? i forgot the color but can look in my manual. the wire originally fed the pwm sol in the auto tranny.
Old Apr 5, 2005 | 09:08 PM
961le's Avatar
Wink Re: Problems wiring reverse lockout
brown wire is 12v and the pink wire is grd. both were part of the 20 pin connector to the auto tranny. i can only assume the wire colors did not change from my 96.
Old Apr 5, 2005 | 09:16 PM
961le's Avatar
scratch that pink is 12v and brn is ground.
Old Apr 5, 2005 | 09:48 PM
94 NO TOP Z's Avatar
After 6 months I finally wired mine up. Tired of 2 fisting it into reverse. Seems to work fine... did you hook the ground into the D6 of the BLUE connector on the PCM? Switched power to the other?
Old Apr 6, 2005 | 12:35 PM
I'll take it apart and switch the wires to see if that fixes it. I forgot what I wired the other wire into but I'm going to have to go back in and check..
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
PCLZ28
Dec 24, 2015 05:19 PM
Scottyboy
Feb 11, 2015 10:28 PM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
