Problems problems problems....
Old Dec 1, 2003 | 05:37 PM
BigTed187's Avatar
I just put in a New EGR valve since the dygnostics came up code 32...but i was wondering since my problem still occurs could it be the pcm?? also i have a popping backfire noise when its in drive while im still with my foot on the brake?? any ideas??? thanx its a 95 z28 stock...
Old Dec 1, 2003 | 05:44 PM
Fastbird93's Avatar
If the code 32 was the EGR code, and you replaced it with no improvement, it could be blocked passages.....
Old Dec 1, 2003 | 05:53 PM
llafro's Avatar
If you have a service manual, it lists a whole series of steps to take before replacing a component. Often, the problem lies not in the part itself, but rather in the wiring or vacuum lines leading to the valve. Without checking those first, it is hard to say. To check the system, you will likely need a volt meter and vacuum gauge/tester.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
