problems please help
Old May 14, 2005 | 07:45 PM
Jakeav11's Avatar
so the mechanic said that i need to remove the engine to remove the heads to drill out a manifold bolt/stud (2 of them) on the drivers side and i was wondering if this is true and if anyone knows of a guide to remove the heads please show me
thanks in advance
Old May 14, 2005 | 11:27 PM
JB94's Avatar
Re: problems please help
Remove the engine I don't think so.You can remove the head with the engine still in the car.I did this a while back myself.A good basic source of info would be the Haynes repair manual for these cars.Two big trouble spots to look out for when removing acylinder head on the LT1 are ;more broken manifold studs and removing the coolant crossover tube that connects both heads at the rear without damaging it.
Old May 15, 2005 | 12:30 AM
Heatmaker's Avatar
Advanced Member
I think it's time to find a new mechanic....
and where are the studs broken? THere's quit a bit off room to dabble with on the driverside?
Old May 15, 2005 | 01:07 AM
Jakeav11's Avatar
the last two toward the rear of the engine drivers side
Old May 15, 2005 | 01:09 AM
Heatmaker's Avatar
Advanced Member
those aren't that bad to get to from underneth the car... if you have a dremmel and some patience. Now tapping in a new thread... that will be crap.
If your manifolds off...on the driverside... and you remove your steering linkage... I think you should have plenty of room toget the job done yourself.
Old May 15, 2005 | 01:11 AM
Jakeav11's Avatar
i can get $15/hr labor cost...do you have any estimate on how many hours it would take a mechanic to do that?
Old May 15, 2005 | 01:15 AM
Heatmaker's Avatar
Advanced Member
depends on thier tools and thier knowledge... who really knows.
If It's that severe... I'd rather take the head off myself and let a machine shop do all the dirty work to the head. But there's a way around everything.
Old May 15, 2005 | 01:18 AM
Jakeav11's Avatar
thanks a lot...ill let you know how it goes
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
