Problems with monster tach....
Old Jun 24, 2003 | 09:36 PM
96 WS6's Avatar
I just finished hooking it up 15 minutes ago. The dial light bulb is out (already knew that before isntalling it) and I am going to get the bulb asap but I don't know if that's whats causing my problems. First of all the shift light stays on constantly. Second of all, when I turn the key 'on' the RPM goes to 0 as it should. Then when I start it, it bounces around for a sec then goes back to zero. Then when I try to set the shift RPM I press the little red button and it goes behind zero and I turn it both ways and it does nothing. What could be the problem here? I know that setting the shift point has nothing to do with calibration, I am hoping that the dial bulb has something to do with it. We'll see, anybody have those same symptoms???
Old Jun 24, 2003 | 10:14 PM
ollie-99's Avatar
u gotta have it hooked up to the green wire on the coil
Old Jun 25, 2003 | 02:53 AM
96 WS6's Avatar
I think you mean the green wire from the tach goes to the white wire on the coil. Yes it's hooked up right... I think it may not be calibrated right? It says something about loops you have to cut in the instructions. I don't know if the previous owner pushed them in or something, all I know is that it came off of a 4 banger toyota. Can I open the gauge without messing anything up to check it out???
Old Jun 25, 2003 | 03:36 AM
whitehooptie's Avatar
If it was on a 4 cylinder, then the wires were cut. Just take it apart and reconnect them. Should be good to go.........unless the needle is whacked out now.
Old Jun 25, 2003 | 02:24 PM
96 WS6's Avatar
I opened it and the brown wire was cut. I reconnected it and I still have the same problem... Why would my shift light stay on? I don't get this.
Old Jun 25, 2003 | 06:02 PM
Did you accidently hook the green wire to the positive maybe? How mush did you buy this tach for? If you got it pretty cheap, I think you can guess the problem.
parkers Z28
Mar 11, 2016 08:14 PM
Cam's maro
Dec 28, 2014 09:30 AM
ithacamike
13
Sep 15, 2002 05:55 PM
