problems after LT's and y-pipe
Old Sep 9, 2005 | 11:29 PM
key3's Avatar
hi I just installed some pacesetter LT's and y-pipe and have problems when I am at WOT it feels like the exhaust is coming through the floor board. Just by crawling under and looking at it the y pipe is not rubbing anywhere.
thanks
Josh
Old Sep 9, 2005 | 11:45 PM
Birdman7389's Avatar
Re: problems after LT's and y-pipe
Nope, its rubbing. Probably where the drivers side y-pipe comes near the frame brace/crossmember.
It will clearance itself over time, or you can get under there with a BFH and do it yourself.
Old Sep 9, 2005 | 11:46 PM
'94 Bad A Z28's Avatar
That is exactly the problem.... you need to try to fabricate some type of brace between the body of the car and the y-pipe right there under the driver seat.
Old Sep 9, 2005 | 11:47 PM
2000GTP's Avatar
How old are the motor mounts? Worn mounts can usually cause the headers to contact various places. Also, its not always noticable, but at the end of the y-pipe, right around that flimsy chassis brace, that is a good spot for the ypipe to hit.
Old Sep 10, 2005 | 12:43 AM
3gc's Avatar
3gc
I had this problem when i first installed my pacesetter LTs. A friend of mine gave me a trick to use. It worked fairly well too. You support the transmission, remove the crossmember, lower it a little, put a peice of wood, 2x4 or something between the frame and the flat spot on the y-pipe, then slowly lift the transmission back up. Should flatten the pipe a little more and provide enough room. I did that and now it only does it under hard acceleration in first or second gear. I blame it on the tranny mount though, one side of it is seperated. New one should be here monday though and hopefully it'll fix it.
Old Sep 10, 2005 | 12:48 AM
CamaroSS30thAnn's Avatar
yep motor mounts and headers are almost a must , or at least for me it is
ur motor is torqing to teh right and bringing teh driver side y-pipe onto ur floor member
i installed poly mounts and my motor doesnt even move, if it does its ever soo slightly lol
Old Sep 10, 2005 | 11:50 AM
key3's Avatar
I put some washers under the cross member but I do notice one spot, that brace that goes from the rearend to the transmission the y- pipe is sitting right on it. I am sure the motor mounts and trans mount has never been changed. Where can I buy some good mounts from? thanks for the help I thought I did something wrong.
R@mpage
Apr 20, 2015 10:02 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
Mike94ZLT1
Jul 31, 2002 01:50 AM
