Problem since headers
Old Aug 16, 2003 | 03:35 PM
doodad's Avatar
Question Problem since headers
Since I put on my long tube headers (with emissions) except obviously cats, I have a strange problem when the car is cold
It runs a little rough, stumbles and surges in the first few blocks. It prefers lower rpms during this time. When it goes in to closed loop, it runs like a champ. But if it sits for ten minutes, even though the temp is up it still exhibits the same, but not as bad, symptoms. It also is throwing the EGR malfuntion code but I cleaned the EGR, vacuum tested it, and checked the solenoid. All OK. I checked the O2s on auto tap as well and they and the sims in the rear are moving like normal. My mechanic thinks it is the sims, but I disagree as this started before the sims were installed. I have LT1edit now, and plan to turn the EGR off. What do you guys think this is, and do you think turning off the EGR will fix it? TIA
Old Aug 17, 2003 | 02:30 AM
doodad's Avatar
have a heart for a guy who had to buy the wife a new car today!
Old Aug 17, 2003 | 03:23 AM
Dave19yz28's Avatar
yes, i think it will fix it. When i got rid of my EGR, it fixed my idle issues i was having. Also, check around for vacuum leaks. Good luck.
Old Aug 18, 2003 | 04:03 PM
doodad's Avatar
Unhappy
anybody else?
Old Aug 18, 2003 | 04:13 PM
madwolf's Avatar
Turning off the EGR code will most likely not fix this. I would check for burned wires, or for wires that are too close to the manifolds.
Old Aug 19, 2003 | 08:16 AM
doodad's Avatar
Thanks Ion. How about the opti? Could it cause this behavior, because we were seeing random misfires. I have ordered the opti, should be here tomorrow.
Noenav
Mar 1, 2019 07:38 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
