Problem with KS removal??
Old Feb 24, 2005 | 11:00 PM
Jps 1LE's Avatar
Sup everyone
Been doing some searches but have turned up with little info on my problem. I've been trying to remove my knock sensor with no luck so far. As i turn the wrench all that moves on the knock sensor is the middle piece. It doesn't even seem to budge the threads at all. When i started i used a little bit of pressure and the middle started to turn but the sensor was not moving off the block. My questions would be:
Is the KS broken? How do i go about getting this off? And has anyone ever had this problem before? Any ideas would be appreciated...
Old Feb 25, 2005 | 01:00 AM
zx1216's Avatar
Re: Problem with KS removal??
mine was a pita to get out as well and i allready had a new one so i just used a pipe wrench on the round part of the sensor, also be prepaired for a coolent shower when u get it out.
Old Feb 25, 2005 | 01:03 AM
SS MPSTR's Avatar
Yes. And make sure you bleed the coolant system completely and properly when you put all that coolant back into the car.
Victor Lamb
Aug 26, 2017 02:52 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
StansZ28
Feb 19, 2015 07:39 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
97SSdude
Dec 31, 2014 07:43 PM
