This is a problem isint it????
Old Aug 11, 2008 | 06:50 PM
TeamingTealZ28's Avatar
Trying to pull this plug I used a screwdrive and it cracked the opti itself.
The opti only has like 20K miles on it.
Old Aug 11, 2008 | 06:52 PM
Green96Z's Avatar
A crack there could let moisture into the opti. The pic is kinda blurry, it could not be bad at all. How bad does the crack look?
Old Aug 11, 2008 | 06:58 PM
Potential problem, yes.
Old Aug 11, 2008 | 07:27 PM
What if i put some like bulb grease right there..to like repel moisture and water?
Old Aug 11, 2008 | 10:47 PM
Not going to last. With all the dirt and grime, you are going to need to take it off and try to repair it with some epoxy or something of that nature.
Old Aug 12, 2008 | 11:22 AM
reamo04's Avatar
i was thinking some RTV
Old Aug 12, 2008 | 11:27 AM
cause4panic's Avatar
Jb Weld
Old Aug 12, 2008 | 11:51 AM
Connexion2005's Avatar
Use rtv. It will provide the best seal against weathering and provide a decent hold for the crack. Or to be safe and give the best finish use JB Weld to repair the foundation and then rtv for sealing any potential leaks. It looks salvageable to me so I would atleast give it a shot. The unit should not be under to much stress right there so the steps I mentioned should last.
Old Aug 12, 2008 | 11:54 AM
JoeliusZ28's Avatar
I would use Permatex 'right stuff' and I doubt it would be a problem.
Old Aug 14, 2008 | 08:59 PM
wrd1972's Avatar
If Billy Mays were on the board he would say "throw some mighty putty" on it.
https://www.mightyputty.com/spark/in...ag=mpedseag100
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
