Problem with the car...
Old Aug 2, 2004 | 02:51 PM
fesgali's Avatar
It started a while ago after i put the ASM headers on the car. First it would only do it right before it would shift into another gear up around the 5krpm range, i think it's the 2-3 gear shift. Sounds like the driver side of the engine would pop/bang hard and the rpm would drop and pick back up, this would happen a few times before it would shift.
Yesterday i hit it hard from a stop and it got up to about 4-5k rpm and it started doing it in first gear. The rpm droped a few times and then i just eased up off the car before i break somethin.
This is really pissen me off cause i can't do any hard runs with the car or else i hear pop/bang and power is shot to hell.
I got auto 95 z28, 8mm taylor wires, ngk plugs, asm headers, cat, slp lm, morosso cai.
anyone got any ideas?
Old Aug 2, 2004 | 02:57 PM
GreenDemon's Avatar
Re: Problem with the car...
Does the tach jump around a lot at those rpms?
And do you have difficulty making it to redline?
Old Aug 2, 2004 | 03:00 PM
fesgali's Avatar
In P or N(stopped or rolling) i can rev the car up to about 6krpm with no problem.
And when the bang/pop starts to happen ya the rpm jumps alot.
Old Aug 2, 2004 | 04:19 PM
fesgali's Avatar
ttt
Old Aug 2, 2004 | 04:43 PM
cmking26's Avatar
I would check the opti crap. The popping could be it miss firing. Did it get wet, coolant spill, or is it old?
Old Aug 2, 2004 | 04:45 PM
fesgali's Avatar
It was in the garage for about 3 weeks before i started to drive it again, so i dont' think it was wet. It's got about 11X,XXX miles on it. I dont' see any coolant leakage anywhere out side.
Could it be detonating?
Old Aug 3, 2004 | 11:46 AM
fesgali's Avatar
ttt
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
Ryabut98
Sep 3, 2002 11:45 PM
TedH
Aug 20, 2002 04:58 AM
Darth Xed
15
Jul 31, 2002 04:46 AM
