problem after LT install
Old Jun 1, 2006 | 10:52 PM
Josh3111's Avatar
after installing my long tube hookers and y pipe I am having trouble in the rain..I checked for leaks in the hose to the weep hole and there is no leaks...the optic spark unit looks fine..it seems to have no cracks....has anyone had this problem?
I have a 97 Z28. It seems like it is not firing right and i lose all power..any suggestions?
Old Jun 1, 2006 | 10:54 PM
Austin96Formula's Avatar
Re: problem after LT install
Check for burned/broke wires. That's what happened to me on my LT install years ago.
Old Jun 1, 2006 | 11:12 PM
Robs97Z28's Avatar
did you keep all of the stock heat shielding?
Old Jun 1, 2006 | 11:30 PM
user 647483's Avatar
Went though two sets of wires before I got smart and ran OTVC
You can route stock wires away from headers safely if you get creative.
I know there are a few board members who've figured it out.
Old Jun 1, 2006 | 11:46 PM
Josh3111's Avatar
I bought this Z28 from my uncle..all i know is that they took out the smog pump..as far as the heat shield I am not sure...
Old Jun 2, 2006 | 01:11 AM
CAMSS30's Avatar
You have burnt wires gauranteed, i went through 5 wires when i did LT's.
Old Jun 2, 2006 | 06:27 AM
94_PatriotRed_Z's Avatar
I have not burned 1 plug wire yet, granted I did burn the starter wire. Im running stock plugs, with heat shields on everyone
97Z28Muscle
Feb 6, 2015 10:44 PM
97SSdude
Dec 31, 2014 07:43 PM
Red97LT1
Sep 7, 2002 09:29 PM
yosshimura
Aug 12, 2002 06:47 AM
Chrisdude
Jul 24, 2002 02:25 PM
