350 CI Power
Old Jun 1, 2006 | 01:13 AM
mccullar_racing's Avatar
350 CI Power
WHat kind of power is possible with a stock Ci LT1? Also, what heads/cam is needed for this? Thanks for any imput.
Old Jun 1, 2006 | 02:00 AM
urbaNHunter44's Avatar
Re: 350 CI Power
How much are you willing to spend?
But eh... 420+ rwhp N/A with ported stock heads is possible with good street manors still.
Old Jun 1, 2006 | 02:02 AM
Re: 350 CI Power
The money is not in the equation.
I really dont care about the street manners. It is going to be a race only build.
Old Jun 1, 2006 | 07:05 AM
sssalah's Avatar
Re: 350 CI Power
With high compreession, a big solid roller, a single plane conversion and the ECM to support 7000+ rpm, 500 wrhp is not out of the question.
Old Jun 1, 2006 | 07:49 AM
TQdrivenws6's Avatar
Re: 350 CI Power
If you build a 355, you can turn the rpm necessary to make power. If you get it set up correctly with a well ported aftermarket casting, Super Victor intake manifold converted for LT1/EFI, solid roller, high compression, and all the supporting mods you could certainly hit 500rwhp but it isn't going to be cheap.
Old Jun 2, 2006 | 12:47 AM
Re: 350 CI Power
What kind of money are we talking here?
Old Jun 2, 2006 | 06:36 AM
Re: 350 CI Power
A good solid roller 355 will have ~$1200 in the bottom end, $1000 in machine work, $2500 minimum in the heads (aftermarket castings plus porting), $3000 in the intake/valvetrain/cam, $1500-2000 for aftermarket engine management, and a $1000-$2000 for bolton's depending what you need.
The cheap way to 500rwhp is a cheap 355 (good pistons, rods, and the stock crank) with a cam and a big shot of nitrous. It will get there on stock heads even.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
XtremeLt1
Sep 13, 2002 08:50 PM
