Problem with 160 stat install. Just cracked the bolt PICS, ideas?
Old Jun 15, 2003 | 03:55 PM
  #46
yorkie's Avatar
blow the hole out with...
compressed air first to remove chips etc, wear glasses too.
Old Jun 15, 2003 | 03:56 PM
  #47
dak125's Avatar
Re: blow the hole out with...
Like that can of air stuff? I don't have any of that laying around.
Old Jun 15, 2003 | 03:59 PM
  #48
yorkie's Avatar
need to blow the hole out, and only screw
it in by hand first to see if it is OK. If not then you need a tap to clean the threads. Air compressor or the can of air (like computer people) use
Old Jun 15, 2003 | 04:04 PM
  #49
PatriotTA's Avatar
Yeah, compressed air would not be a bad idea to blow the debris out of the hole with. Just make to to cover your t-stat and throttle body (and wear glasses or look away like yorkie said). It doesn't matter if the cover is on or not, you just want to make sure the threads are in decent condition. Don't tighten it down with the cover off, you are just checking the threads. When you actually run the bolt in, it doesn't matter what you use. You can use any tool you like. For stuff like that, I like to use a ratchet with an extension. Just whatever fits in the space the best.
Old Jun 15, 2003 | 05:52 PM
  #50
dak125's Avatar
I got some compressed air, sprayed it out and slowly put the bolt back in. I'm in a little farther in then last time but it's got some major resistance. Here is how far in they are:
Pic 1:
http://www.dakology.com/images/new%20bolt%20in%201.JPG
Pic 2:
http://www.dakology.com/images/new%20bolt%20in%202.JPG
Pic 3:
http://www.dakology.com/images/new%20bolt%20in%203.JPG
Should I really give it some pressure? But, I'm sure I'll break the damned thing again. Now what?
Old Jun 15, 2003 | 06:09 PM
  #51
Pic 1:
Pic 2:
Pic 3:
Best bet would be to run a tap into the hole to clean up the threads. Could you get by just adding a few washers to the bolt? Maybe, if there is enough threads of the bolt down in the hole.
Old Jun 15, 2003 | 06:11 PM
  #52
dak125's Avatar
When I went to Ace this morning and bought this stuff I looked at taps. The only one they had was for a drill. They also had screws that thread themselves. But the guy that helped me said there's a good chance of screwing it up even more. I could basically start threading new threads. You think I could maybe put a nut on there?
Old Jun 15, 2003 | 06:23 PM
  #53
PatriotTA's Avatar
As I see it, you have 3 options right now
1) Go to Sears and buy a tap for that hole to chase the threads
2) Get more washers to stack up and make up the difference
3) Torque that sucker down there (I don't reccomend that at all, however)
HTH
Old Jun 15, 2003 | 06:24 PM
  #54
dak125's Avatar
How about a nut in between the washer and the bolt? Think that would hold? As long as it'll hold is all I'm concerned about.
Old Jun 15, 2003 | 06:29 PM
  #55
PatriotTA's Avatar
I'd suggest the washers
Old Jun 15, 2003 | 06:31 PM
  #56
dak125's Avatar
You think this will hold though?
Old Jun 15, 2003 | 06:36 PM
  #57
dak125's Avatar
What are your thoughts on lock tight? Would this solve the problem for permanent hold? But then I won't know if I did this correctly
Old Jun 15, 2003 | 06:39 PM
  #58
PatriotTA's Avatar
For Locktite to work, you need the bolt to be snug anyway. It just keeps an already seated bolt seated. Trust me on the washers. Instead of having that one like you have in the pic, you will have like 5 or something. See if you can get a couple of thick washers from the hardware store. So the washers are between the head of the bolt and teh base of the t-stat cover. Just make sure the head of the bolt is bigger than the inner diameter of the washers.
Old Jun 15, 2003 | 07:41 PM
  #59
anaik's Avatar
Why not get a shorter bolt instead of stacking washers. Just use one washer to imitate the original head that broke off.
Old Jun 15, 2003 | 07:49 PM
  #60
dynomight's Avatar
I think craftsman makes some bits now that can be used to back out screws(like reverse drill bits), maybe a similar tool for this problem...
