Problem with 02
Old Jun 17, 2008 | 09:42 PM
jimmybodytop's Avatar
Post Problem with 02
got problem with my lt1 it run not to bad when its cold open loop
but on the highway at 3000rpm it try to go close loop but its start to hesitate and give me right 02 fail code and get back to open loop mode
and i get some little miss on idle
got a datamaster log of it
its lt1 caddy 1996 with pcm from caprice 1995 reflash pcmforless
Sylvain
Old Jun 18, 2008 | 01:44 AM
Dadic 78's Avatar
replace your 02.
Old Jun 18, 2008 | 06:15 PM
What was the specific code for the O2 sensor? There are more than one, and none of them is "fail".
Old Jun 21, 2008 | 01:20 PM
in me my datamaster file it said right 02 fail i change my 02 and test all the wire to the pcm make the of shorting to ground high and low o2 wiring from pcm
and still got 453 on the right 02
on the left it change to 55-400 on ignition on only
Sylvain
Old Jun 21, 2008 | 01:42 PM
You got DTC 63 (that's the number I was looking for). When you get the codes, rather than use the shorthand descriptions in DataMaster, use Shoebox's list:
http://shbox.com/1/Dtcs.htm
63 Bank 2 = (right) Heated Oxygen Sensor (HO2S) Circuit (open circuit)
The open circuit could be faulty wires/connector, or the sensor itself. I can't really understand how you tested the wires:
i... test all the wire to the pcm make the of shorting to ground high and low o2 wiring from pcm...
If you could explain that, might be able to help. If you mean you connected the two wires from the PCM together at some point, and you still had 450mV on your scanner, the fault would be closer to the PCM than the point where you connected the wires together. If you hook a high impedance volt meter to the tan and purple wires at the harness connector, what does the meter read?
Old Jun 21, 2008 | 02:04 PM
i plug datamaster short the tan and purple wire to ground and it change in th pcm to 9-10
i read that in the service manuel of caddy 94-96
but on the right it stay at 453-458 when i connect it to the pcm with the car not running
Sylvain
Old Jun 21, 2008 | 11:01 PM
When the O2 sensor is cold, and the engine is not running, you will see ~450mV on a scanner. The PCM itself supplies that voltage. You have to look at the O2 signal as the engine warms up, and the sensor gets hot enough to generate a voltage of its own.
The tan wire is in effect the "ground". Not sure why you want to short the purple wire to ground. And what does " ...it change in th pcm to 9-10" mean? 9-10 "whats"?
Have you compared the ledt and right sensor signals with the engine cold and not running?
Old Jun 22, 2008 | 11:08 AM
it said in the manuel that you are supposed to have like 200mv or less when you short these wire to ground
but when the truck get hot the signal on the left varies but the one on the right stay at 453-458
i compare with the left and got 9-10 when i short the purple and tan wire
to ground
i could send you my datamaster files i you want to take look at ?
Old Jun 22, 2008 | 02:12 PM
to ground
9-10 WHAT????? Volts, amps, millivolts?????
If you have replaced the sensor, then you have an open circuit between the PCM and the O2 sensor. If you haven't replaced the sensor, swap the left and right sensors, and see if the problem follows the sensor to the left side ( = faulty sensor) or stays on the right side ( = faulty wiring). You don't need someone to look at the DataMaster log. You need to check the things I'm suggesting, and please.... please.... answer the questions I am asking. If you prefer not to answer the questions, and to follow you manual, then tell me and I will back off trying to help, so I don't interfere.
Old Jun 22, 2008 | 02:28 PM
so lets forget about the manuel
i switch the 02 and the problem stay on the right side so i check and ohms test my wiring to the pcm and it test ok
so the problem is maybe in the pcm itself
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
