Priming the Oil Pump
Me and a friend are dropping a remanufactured LT1 into my 95 Z28. Basically what i need to know is how to prime the oil pump on an LT1. Any information would be very appreciated.
only way I know to do it is with the intake off.. spin the oil pump drive with a angel drill and the tool used to turn it. then put the intake on pull the coil wire off and crank the motor over untill the oil pressure goes up agian. then put the coil wire back on and fire it up..
NEWBIE T/A
Jun 14, 2002 12:27 AM
