hub install
Old Aug 30, 2003 | 06:58 PM
kcz28's Avatar
hub install
I was just wondering what would be the best way to install the hub. Have any of you guys who used a block of wood and a hammer experienced any problems?
Old Aug 30, 2003 | 07:10 PM
Mr.Whitey's Avatar
You've got a few options. First would be a crank hub installer. It's basically a long bolt looking device that costs about $40. AutoZone used to have them as a loan-a-tool so it's free. Eastwood sells them also. Second would be to buy a NEW crank bolt and just tighen the thing back on. I tried the wood before and had no luck.
That's just my .02
Old Aug 30, 2003 | 08:13 PM
Dave Feerst's Avatar
use a hub installer or you risk destroying your crank.
I rented one from autozone.
Old Aug 30, 2003 | 10:41 PM
nateh's Avatar
I use 7/16 threaded rod and thread it to the bottom. Then I can use the washer that goes under the hub bolt and a 7/16 nut to pull it on. I pull it on by hand and it's always gone on well.
Old Aug 30, 2003 | 11:06 PM
That's a 7/16-20 thread (fine thread).
Old Aug 30, 2003 | 11:07 PM
nateh's Avatar
Yup. Thanks for the clarification.
Old Aug 30, 2003 | 11:09 PM
atljar's Avatar
USE ONLY A HUB INSTALLER!
Hitting it on is hell on the thrust bearings.
Using that bolt to pull it on is risky. If your doing it this way, buy a NEW bolt. I broke mine off in the crank pulling the hub on using the standard bolt which had been used several times to pull the hub on already. The broken part is in no way removable (tried welding to it and everything). Only thing holding my hub on now is the press fit and red locktight.
Old Aug 30, 2003 | 11:11 PM
thewinner's Avatar
i tried the rod thing, didnt feel right, felt like the threads were going to get messed up.
So i just beat the **** out of the hub with a hammer and it went on, probably not the best for it, but its been working ever since
Old Aug 30, 2003 | 11:18 PM
Mikey97Z's Avatar
I bought a 3 foot piece of hardened rod to make my hub installer (which works for crank sprockets too ), and I have enough left to make 2 or 3 more if anyone wants some I'll cut it up and mail it for 5 bucks. Just email me.
Old Aug 31, 2003 | 01:36 AM
95m6's Avatar
While we're on the topic of harmonic balancers and everything, when we pulled off my harmonic balancer, we seperated the pulley and the actual hub into 2 pieces before removing. Not knowing that we could have left it one piece and pulled them together (Just did it the way the Haynes Manual suggested..). Anyways, now that we're gonna be putting it back together pretty soon, what would be the best way to do that? Thanks, I didn't want to just beat it back on thier. Who knows what all I would mess up that way...
Old Aug 31, 2003 | 12:38 PM
kcz28's Avatar
Question
Ok, I went to autozone to rent the install tool. It seems that I have to get the hub up to the oil seal on the time cover to get the 7/16 extension to thread into the crank.
The only problem with this is that I only can get the hub on the very tip of the crank, by hand. This problem is very similar the problem I faced when removing the hub. How do I get the hub further on without beating it.
Old Aug 31, 2003 | 01:00 PM
Mr.Whitey's Avatar
Try starting it w/ the factory bolt but don't use the spacer. That should be enough to get it going.
Nov 18, 2023 07:21 PM
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
