Primary Lengths?
From what I've heard, header wrap will cause headers to prematurely degrade. Probably because it keeps all the exhaust heat inside the header, which is a good thing for a race car, but unless you've got money to replace your headers every so often, I'd stick with a good ceramic coating of some kind instead. Just my opinion, though.
It doesn't cause them to degrade, but you can't put any protective coating on them like Jet Hot since it eats up the coating, so unless they are stainless they are going to rust faster since there is nothing protecting them.
Bret
Bret
Bret
Bret
"Degrading" and "rusting faster" are one and the same are they not? Or should we say "oxidation"?
I wouldn't recommend wrapping a mild steel header. It will speed the oxidation of the metal by keeping the header hotter and retaining moisture.
Just my 2 centavos.
-Mindgame
Just my 2 centavos.
-Mindgame
Originally posted by Red96Lt1
I would just route them over the valve cover's if you haven't done so already. Don't cover up those pretty headders.
