Headed To The Track!! Predictions???
Old May 7, 2004 | 11:44 AM
Berly_BoneStock's Avatar
Just wanted to know what you guys would think i would run with mods in sig.
Thanks again guys!
Old May 7, 2004 | 11:59 AM
Valkyn71's Avatar
12.67
Old May 7, 2004 | 12:02 PM
LREFLYBYOU's Avatar
Im gunna go with 12.90's...You beefed up the cam which is great,but u didnt touch the heads or valves...at least from what you stated...So now your gaining from the cam but at the same time your kinda hurting urself bc the motor isnt breathing any better with those stock heads...port the heads and intake to match,put 1.6 rockers on it and watch ur ET drop to a 12.40 or so....
Old May 7, 2004 | 12:05 PM
LREFLYBYOU's Avatar
Oh and if its an automatic id recommend a 2200-2500 stall converter,friendly on the street and it will be perfect for the cam RPM range!
Old May 7, 2004 | 12:44 PM
Mine is an m6. Hopefully ill be pleased with my times. If anyone else wants to chime in i would appreciate it!
Old May 7, 2004 | 01:05 PM
turbo_Z's Avatar
If you are running street tires then probably high 13s.... if you throw on some good drag radials then my guess would be 12.9XX.
Old May 7, 2004 | 01:08 PM
badblackta's Avatar
I second that. Dont matter how much power you got if it aint gettin to the ground. Slicks or drs and you will be movin
Old May 7, 2004 | 01:10 PM
any tips for launchin this sucker.
Old May 7, 2004 | 01:13 PM
badblackta's Avatar
slip the clutch alot and leave from idle. Or nail it then feather the clutch to stop spinnin then nail it again.
Old May 7, 2004 | 01:26 PM
Anyone else want to throw in their two cents???????????????????????????????????????????
Old May 7, 2004 | 01:52 PM
96capricemgr's Avatar
That track sucks wed. night the LS1 guys were having trouble finding 14.1, prep is horrible, maybe MPH guesses would help more since the track is slow. Exeryone there says GLDW is 2-3 tenths faster.
Old May 7, 2004 | 03:17 PM
jasons93z's Avatar
What???? I ran 13.7 on street tires with my m6 with way less mods and im no pro.
Old May 7, 2004 | 03:32 PM
speed_demon24's Avatar
Um, I'm a full weight bolton LT1 running 13.0's on street tires. I say high 12's on street tires, mid-low on dr's depending how well it hooks and how much you are willing to risk with the 10-bolt.
Old May 7, 2004 | 06:08 PM
LREFLYBYOU's Avatar
jus leave like ur leaving from a stop sign only with a lil more gas...gotta keep it engaged a lil...
Old May 7, 2004 | 06:35 PM
Johnnynsac's Avatar
I'm thinking it's going to rain that day and ummmm, your not going to the track.
I'd say about a 12.7ish
