Primary Lengths?
Old May 9, 2004 | 05:55 PM
Black_Z28's Avatar
Primary Lengths?
Does any one know the primary lengths on TPIS mid-length headers? Thanks.
Old May 9, 2004 | 07:33 PM
SStrokerAce's Avatar
The average primary length on those is 18"
Old May 9, 2004 | 08:01 PM
Black_Z28's Avatar
Alright thank you. I'm just trying to figure out how much header wrap I'm going to need. I guess I'll need about 35 feet if the average is about 18".
Old May 9, 2004 | 08:16 PM
96ss2nv's Avatar
From what I've heard, header wrap will cause headers to prematurely degrade. Probably because it keeps all the exhaust heat inside the header, which is a good thing for a race car, but unless you've got money to replace your headers every so often, I'd stick with a good ceramic coating of some kind instead. Just my opinion, though.
Old May 9, 2004 | 09:30 PM
It doesn't cause them to degrade, but you can't put any protective coating on them like Jet Hot since it eats up the coating, so unless they are stainless they are going to rust faster since there is nothing protecting them.
Bret
Old May 9, 2004 | 10:05 PM
Bret
Old May 10, 2004 | 11:50 AM
Black_Z28's Avatar
I have Jet-hot coated headers. So should I pass on the header wrap? I want to put it on my car so I don't have to worry about my spark plug wires as much as I do now.
Old May 10, 2004 | 12:33 PM
Red96Lt1's Avatar
I would just route them over the valve cover's if you haven't done so already. Don't cover up those pretty headders.
Old May 10, 2004 | 01:14 PM
Mindgame's Avatar
"Degrading" and "rusting faster" are one and the same are they not? Or should we say "oxidation"?
I wouldn't recommend wrapping a mild steel header. It will speed the oxidation of the metal by keeping the header hotter and retaining moisture.
Just my 2 centavos.
-Mindgame
Old May 10, 2004 | 03:02 PM
Black_Z28's Avatar
I have over the valve cover wires, and I really dislike how they looks. So, I'm going back to the stock locations. I guess I'll just end up taking my good time while installing the plugs.
13qtr
Oct 28, 2016 08:11 PM
FredM
Exhaust System
Feb 8, 2016 02:10 PM
93 RedBird
Nov 15, 2015 08:24 AM
POLOVETTE 94
Aug 21, 2015 07:11 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
