Pressure escaping through gas cap!!!HELP
Old Jan 5, 2006 | 12:25 AM
Deenasty's Avatar
Well I was having a problem with the car building too much pressure in the gas tank, and a awful fuel smell in the interior. I Pulled the charcoal canister off today, and after shaking it, you can hear all the charcoal. Upon turning it upside down, a lot of charcoal came out. I replaced the charcoal canister, and the gas cap (non vented). After a small drive tonight, I got home turned the car off, and I could hear a "hissing" coming from the gas cap. I removed the cap, and almost gone blown away from the amount of pressure in the tank. What can this be, and how can I solve it? Gas tank vent clogged? Vented gas cap? Part number? Thanks a lot guys!
Old Jan 5, 2006 | 12:30 AM
OBE1 95Z28's Avatar
Re: Pressure escaping through gas cap!!!HELP
The gas tank has a pressure relief valve; it's located above the rear axle mounted close to the driver's side spring.
Old Jan 5, 2006 | 12:34 AM
Deenasty's Avatar
Is it the "Fuel Tank Vent" in the following picture
Old Jan 5, 2006 | 01:56 AM
Deenasty's Avatar
also, when I removed the EVAP charcoal canister, the "Air inlet" tube( middle of the tank tube, and purge tube), it was not connected on the other end, could this be the culprit?
Old Jan 5, 2006 | 12:17 PM
Deenasty's Avatar
please help guys!!
Old Jan 5, 2006 | 12:57 PM
OBE1 95Z28's Avatar
Yes I was referring to the fuel tank vent from the photo you posted.
calaban
May 18, 2020 06:43 PM
Biggiebound
Apr 23, 2015 08:50 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
blac94Z
Nov 24, 2014 07:12 PM
simple
Aug 11, 2002 11:56 AM
