post your duals and dump pics please
Old Aug 8, 2004 | 02:12 PM
  #31
a mean 94z's Avatar
Re: post your duals and dump pics please
Originally Posted by 96TAblur
Is one side shorter than the other? or is that not finished in the pic?
Mark
It wasn't finished in the pic
Old Aug 8, 2004 | 02:16 PM
  #32
SDAKOVIC's Avatar
Click Link In My Sig.
Old Aug 8, 2004 | 02:27 PM
  #33
PatriotTA's Avatar
Thanks a million! That's the exhaust I want.
How did you get the exhaust over the drivers side?
I was told the suspension gets in the way.
Did you have to cut something up?
Thanks again for the pics,
Mark
All I did was remove the panhard bar brace. I haven't noticed a difference in handling (but then again I have my front swaybar removed and don't corner hard anyway). It just unbolts, you don't have to cut anything up. Also, BMR sells a relocation kit that will drop the upper brace a few inches lower so duals will fit through there. HTH
Old Aug 8, 2004 | 04:14 PM
  #34
Jon 97TA's Avatar
fred, why did you angle the turndowns toward the center of the car? Doesn't that make it a lot louder inside?
edit- oops, nevermind, didn't notice there was more pages.
Old Aug 8, 2004 | 05:02 PM
  #35
Buttercup's Avatar
You can get dual 2.5" pipes over the brace in the stock location. I still don't have any pictures of my setup installed on the car but this is them sitting on the floor. http://community.webshots.com/photo/...64324709pEpblc
Clearance is extremely tight on this exhaust but I haven't hit anything yet on my lowered car so it was worth the effort. Even with the cats it's very loud though. Of course, if you can handle dumps underneath the car this system is whisper quiet
Old Aug 8, 2004 | 08:09 PM
  #36
Originally Posted by simple
Fred, Borla XR1 mufflers? hows ground clearance? is there more room to have the mufflers up front like that as opposed to the way most others place theirs?
My system just sort of "evolved". Originally, it was a custom 3" Mufflex Y-pipe, with dual 3" Carsound cats. The Y-pipe fed a Mufflex 4" catback. I had the Borla XR1's to run at the track, in place of the cats..... that's why the XR1's are located where they are.
When the car was lowered, everything dragged on the ground. With the car back to stock ride height, there are no clearance problems.
When The Gear Vendor went in, the Y-pipe became useless, so - since its really only a "track" car - I pulled the 4" catback off, and just ran with the Borlas as "collector" mufflers... damn was that loud inside the car. Evrything rattled and shook, including my chest.
Then E'town added a rule that the exuast system had to include a pipe to at least past the rear edge of the door, so I had Mufflex add the 3" straight pipes you see in the picture. It's still pretty loud in the car, and its marginal as far as passing noise at E'town. I did dyno pulls with and without the striaght pipes, and they have no affect on rwHP.
But this year, E'town added yet another rule that the muffler has to have at least 3 (or maybe 2???) baffles. I'm not about to dump even more money into it to run at E'town, so I guess I'll just run at Atco or Island.
I just post the picture because its "different".
Old Aug 8, 2004 | 10:31 PM
  #37
96TAblur's Avatar
That BMR relocation kit is $199.95. Wow, that's a little more than I wanted to spend.
Does anybody else run without the top panhard bar brace?
Can this cause any other problems (safety)?
Anybody give me your opinions, please.
Thanks for your advice,
Mark
Old Aug 8, 2004 | 10:49 PM
  #38
Buttercup's Avatar
Mark
I didn't want to remove the brace. Do you really think you need 3" pipes? My dual, mandrel bent, 2.5" pipes seem to be flowing more than the old Borla. I haven't gotten new track times or dyno figures yet but I've been busy tuning. With just that change it's requiring more fuel both at low and high RPM so I can only assume it's doing its job. I was thinking I'd gain more noise than power with the 3" pipes, and this thing's loud enough! Not to mention the ground clearance is at a premium on my car.
Fitting the 2.5" pipes isn't easy, but they do clear!
Old Aug 8, 2004 | 10:57 PM
  #39
96TAblur's Avatar
Thanks, I wonder if I could keep 3" on the passenger side & 2.5 on the driver's side? Would that make a difference or sound funny?
Mark
Old Aug 8, 2004 | 11:08 PM
  #40
Buttercup's Avatar
Mark
I wouldn't want a mismatched exhaust like that. If it was really a concern you could run 3" up to the axle and step it down to 2.5" from there. The exhaust gasses are relatively cool by then so it won't pose as much of a restriction. You want your mufflers as far away from the engine for the same reason though, and depending on the style of muffler it's not a bad idea to use a larger size for them. Going from a small pipe to a larger one can introduce some turbulence if not done correctly however.
If you're running the exhaust over the axle on either side, you are going to have to shield the gas and brake lines. At that point though you could run oval pipe over the axle without any loss at all.
It really comes down to how much it is worth to you. It can be done, but how much money and time for what gain? For me, I finished my system for a few hundred dollars including pipe, bends, mufflers, tips, x-pipe, and clamps. It's probably fairly equivalent in flow to a 3.5" single system but with better scavenging. I figured the extra cost, noise, and time spent probably wasn't worth any meager power I might have made with dual 3" for my little heads/cam car.
Old Aug 8, 2004 | 11:25 PM
  #41
TCAL95Z's Avatar
Injuneer,
How much was your car lowered or what springs were you using?
I have the Eibach prokit and I was planning on using a set up like yours
for my new engine.
Did you have problems with your torque arm hitting too when the car was lowered?
Old Aug 9, 2004 | 12:01 AM
  #42
95Zdroptop's Avatar
Here are pictures of mine. They show you what kind of clearance you would have. I used 2.5 inch pipe if you are wondering.
http://www.cardomain.com/memberpage/245983/4
Old Aug 9, 2004 | 08:17 AM
  #43
Originally Posted by TCAL95Z
Injuneer,
for my new engine.
I used the Pro-Kit springs, with the QA1/HAL adjustable shocks. Even though I was extremely careful with the lower spring seat position on the HAL's, the front of the car dropped 1.8", and the rear of the car only dropped about 1". And at that level, EVERYTHING under the car dragged on the ground. I had to turn the bolts in the exhaust clamps so they pointed up, instead of down. In NJ the roads are terrible, and a lot of the highways have "ruts" from the 18-wheelers. If I got both sides of the car in the ruts, the bolts would drag on the center peak of the road. Going over a speed bump was impossible. The TA mount as you can see from the picture is the dropped one for the "4" Mufflex", and that dragged on everything too. I really hated the car when it was lowered, and was glad to put it back where it belonged.
Old Aug 9, 2004 | 09:26 AM
  #44
trans9_5am's Avatar
With the QA1's couldnt you just adjust the ride height with them as well?
Brandon
Old Aug 9, 2004 | 09:30 AM
  #45
Shon Herron's Avatar
http://www.scfyb.com/album/displayim...=10089&pos=-82
Hooker LTs, H-pipe, Hooker Aero Chambers dumped at rear axle. At idle it is loud, but not as loud as the bullets that used to be on there. At idle it just has a lot of bass tone to it, I remember this sound when I was in stereo systems....but off idle it is pretty quiet.
