post your duals and dump pics please
Old Aug 8, 2004 | 12:27 AM
  #16
Mindgame's Avatar
Re: post your duals and dump pics please
Good idea Fred. Keeping that gear lube warmed up to reduce parasitic loss huh?
-Mindgame
Old Aug 8, 2004 | 01:50 AM
  #17
aintno6's Avatar
http://home.comcast.net/~lt1mike83/td/7.jpg
http://home.comcast.net/~lt1mike83/td/8.jpg
Old Aug 8, 2004 | 10:55 AM
  #18
-Mindgame
Actually, the excess C-16 coats the differential housing and cools it as it evaporates
They're tilted "in" like that to try and meet the noise level limits at Englishtown - 90dB at 100-ft, under full power. And there's a clamp on the 90 so it can be rotated, and replaced with a Dynatech cone/90 if needed.
Old Aug 8, 2004 | 11:02 AM
  #19
96TAblur's Avatar
Wow, that's cool and different!
Mark
Old Aug 8, 2004 | 11:19 AM
  #20
96TAblur's Avatar
I'm trying to make my duals quieter inside the car. I met a guy that had dual out the back. Only thing is he had it running under his rear axle. I don't want that. But what about running out infront of the rear tire on the side?
Has anyone done this?
What about bigger mufflers or something with a baffle that doesn't cost big $$$'s?
Mark
Old Aug 8, 2004 | 11:40 AM
  #21
flyinZ's Avatar
If you'd like a few of mine, Im sure I could scrounge up a few...Id have to email them to ya..since i dont have a way to host them..
Old Aug 8, 2004 | 12:05 PM
  #22
a mean 94z's Avatar
Here is my true dual setup, these pics were taking before teh dumps and pass. side bullet was put on.
True Dual 1
True Dual 2
And here is a sound clip of my exhaust set up....
Jet-Hot LTs with X-Pipe into Bullets then dumps
Old Aug 8, 2004 | 12:29 PM
  #23
96TAblur's Avatar
True Dual 1
True Dual 2
Is one side shorter than the other? or is that not finished in the pic?
Mark
Old Aug 8, 2004 | 12:51 PM
  #24
PatriotTA's Avatar
Pics are in the sig
Old Aug 8, 2004 | 01:19 PM
  #25
96TAblur's Avatar
Thumbs up Re: post your duals and dump pics please
Originally Posted by PatriotTA
Pics are in the sig
Thanks a million! That's the exhaust I want.
How did you get the exhaust over the drivers side?
I was told the suspension gets in the way.
Did you have to cut something up?
Thanks again for the pics,
Mark
Old Aug 8, 2004 | 01:25 PM
  #26
simple's Avatar
Mark
looks to me like he is not using the upper piece of the panhard rod, thats the only thing that really stands in the way
Old Aug 8, 2004 | 01:29 PM
  #27
96TAblur's Avatar
What does that do to your handling?
Thanks,
Mark
Old Aug 8, 2004 | 01:31 PM
  #28
simple's Avatar
LMAO
do you have balance pipe or anything in there?
Old Aug 8, 2004 | 01:36 PM
  #29
Somnambulist's Avatar
its all about the panhard reloc brackets
  #30
simple's Avatar
Fred, Borla XR1 mufflers? hows ground clearance? is there more room to have the mufflers up front like that as opposed to the way most others place theirs?
96TAblur; i'm not sure how that affects the car at all, i will let the owner splain that one, he drives it and would know of any ill affects it has or doesnt
