Is it possible to put a 95 opti on wrong?
Old Jul 25, 2004 | 11:44 AM
  #16
Greenfire's Avatar
Re: Is it possible to put a 95 opti on wrong?
When your removing the opti and it gets wet b/c of the water pump, is the opti pretty much gone, should I buy a new one, we put it back in and the car isn't running right, backfires when you give it gas, and idles "ok", but in gear it runs bad.??
Greenfire
Old Jul 25, 2004 | 12:32 PM
  #17
carlos64030's Avatar
Sounds to me like you have the opti on correctly. You mentioned that it slipped on very easily, and it was flush against the timing cover.
Old Jul 25, 2004 | 09:33 PM
  #18
Greenfire's Avatar
Any other comments?
Greenfire
Old Jul 29, 2004 | 11:24 AM
  #19
Greenfire's Avatar
ttt
Old Jul 29, 2004 | 11:44 AM
  #20
Lyle A's Avatar
I guess the only sure way to find out is to pull it off again and note it's position.
Old Jul 29, 2004 | 12:18 PM
  #21
TransAmGT's Avatar
We tore everything down again and sure enough it was sitting in the cloverleaf....fixed it and put it back on right now it runs great...the cat was clogged so we punched that out and that fixed the problem that we though was the opti to begin with...anyways...so the answer is yes it can be put on wrong and I did it!
Old Jul 29, 2004 | 12:24 PM
  #22
Lyle A's Avatar
Don't feel bad. Many others did the same thing. I'm pretty sure on 94 it's hard to index it wrong but out of compulsiveness, I pulled mine a couple times to make sure. I also ran it before the water pump went on to verify all was well. So far so good.
Old Jul 29, 2004 | 12:27 PM
  #23
944v8inDFW's Avatar
Thank you for reporting your findings! Hard to admit when you are wrong and i give you a big hell yeah for doing so!
Old Jul 29, 2004 | 12:45 PM
  #24
TransAmGT's Avatar
Yea this tim we cranked it up before putting everything back together just to make sure!!
Old Jul 29, 2004 | 04:17 PM
  #25
Greenfire's Avatar
Do you mean you had the dowel pin in the wrong place? It meaning the dowel pin???
Greenfire
Old Jul 29, 2004 | 07:52 PM
  #26
TransAmGT's Avatar
Yes the dowl pin on the end of the cam wasn't sitting in the correct spot when I put the opti on..I guess it shifted or something...it was sitting in the cloverleaf...all I had to do was take it back off and put it back on!
Sergio
Jan 27, 2016 04:27 PM
grgguy
17
Feb 23, 2015 07:57 PM
capebuf
Jan 13, 2015 07:22 PM
Injuneer
Dec 15, 2014 09:36 AM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
