possible pcm problem
Old Aug 16, 2005 | 11:55 AM
96KillaZ's Avatar
I have another thread about a similar question but this one is more concerning my pcm. All at the same time, my electric waterpump went bad, my fans dont turn on, and my check engine light came on too, but when I go to scan it, the damn code reader will not even turn on. I know the code reader is good because I tried it on other cars. What is wrong?
Old Aug 16, 2005 | 04:17 PM
slopokrodrigez's Avatar
Re: possible pcm problem
More than likely your DLC lost power. Sounds like you have a bad fuse.
Old Aug 16, 2005 | 06:01 PM
96KillaZ's Avatar
what is the DLC? which fuse is bad?
Old Aug 16, 2005 | 06:17 PM
The DLC is the data link connector that you plug the scanner into. Assuming you have an OBDII????? Since you didn't give us details as what year you have. the fuse you want to check is the 25 amp fuse in the I/P fuse box.
If you have a 93 to 95 then you have another problem.
Old Aug 16, 2005 | 10:54 PM
96KillaZ's Avatar
Yeah thanks, I found the fuse and fixed it, now my scanner works, but what about my electric water pump and my fans thay dont turn on?
Old Aug 17, 2005 | 04:59 AM
well considering you have fuse problems, did you check the 25amp fuse #7 in the underhood fuse panel?
DirtyDaveW
Dec 1, 2016 05:37 PM
Scottyboy
Feb 11, 2015 10:28 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
97SSdude
Dec 31, 2014 07:43 PM
JSK333
Sep 9, 2002 10:33 PM
