fan and thermostat turn on question?
Old Aug 16, 2005 | 07:40 PM
djm_e22's Avatar
Alright, when I bought my 96 z28 the guy that previously owned the car had the fan hooked directly to the battery and had a switch in the vehicle to turn the fan on when he wanted to. I am fixing to buy a 160 degree thermostat and due to the fact that I probably can't remember to turn the fan on everytime, I wanted to figure out how to get the fan to turn on automatically I guess when the thermostat opens. Can someone tell me how to do this? Thanks for any help.
Old Aug 16, 2005 | 07:46 PM
2000GTP's Avatar
Re: fan and thermostat turn on question?
The first thing you need to figure out is why the fan is rigged up like that. When I used to work as a tech., I used to get problems like that where people would wire up switches due to their fans not coming on because of a failed fan relay, short, ect. In other words, it might be there to mask a problem.
On to your question, if you want to run a 160 degree stat, a mail order PCM tune will do the trick from Madz28 or PCMs4Less, which will adjust the fan on/off temps automatically as well as many other things.
Old Aug 16, 2005 | 08:25 PM
96capricemgr's Avatar
Very good answer. The pcms in these cars are some of the easierst and cheapest to access and a retuning one is a great mod even for a totally stock car.
Old Aug 16, 2005 | 10:31 PM
There might not have even been a problem before. Maybe the previous owner just wanted to control the fan manually. I don't like how he rigged it up, though.
Old Aug 17, 2005 | 07:20 AM
djm_e22's Avatar
Can someone tell me where I am suppose to hook these wires back up to? Sorry I'm an idiot.
Old Aug 17, 2005 | 08:09 AM
There are fan schematics (use the late production one) on my Tech Page if you want to return it to normal. There are many way to override the fans with a switch. Don't know exactly how yours is done.
HCz28
Feb 15, 2015 03:01 PM
cmdeshon
Dec 27, 2014 10:06 AM
ChrisFrez
Nov 30, 2014 08:41 AM
Jul 4, 2005 05:00 PM
formula79
26
Aug 5, 2002 12:21 PM
