Is it possible to pass emmisions with....
Old Sep 27, 2005 | 12:36 AM
93camaroLT1's Avatar
I am planning on running a switcher chip on my car, is it possible to make a program to pass emmisions by adjusting A/F ratios extremely lean? The car currently has no cat, EGR, AIR, and will be running on open loop due to the fact that i am not using am oxygen sensors in the exhaust. I know emmisions here do not account for NOx (oxides of nitrogen) for whether a vehicle passes or fails, so i was thinking that this might be possible. Emmisions and pass/fail based on hydrocarbons (unburned fuel) and carbon monoxide (i beleive caused by hydrocarbons?). Also, they do not check to see if anything is hooked up, unless you are trying to waiver emmisions based on the fact that you exceeded the $ limit. So techniquely, if I were to run a program with extremely lean A/F at idle and light loads (ex: 16:1) shouldn't I be able to pass emmisions?
Old Sep 27, 2005 | 12:38 AM
Re: Is it possible to pass emmisions with....
i forgot to mention I am also running a cam a little bigger than a CC305 and there is some other stuff done to the car.
Old Sep 27, 2005 | 12:55 AM
Alvin@pcmforless.com's Avatar
Theres a little more to it than that, but yes you should be able to get that cam to pass emissions as long as its not much bigger.
HC's can also go up when you get too lean, CO's shoudln't be a problem.
Old Sep 27, 2005 | 12:58 AM
sweet, I'll be sure to have a "emmisions" program added while I got a wideband on my car. What would be the ideal A/F ratio to pass emmision (without a cat, AIR, EGR), 16:1?
Old Sep 27, 2005 | 01:01 AM
Well, the cam isn't exactly the same as a cc305, it has less duration, mid 220s both sides, but over .575 lift both sides, and 108 lsa
David Dempsey
Mar 12, 2016 12:42 AM
4586
Sep 6, 2015 03:10 PM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
karpetcm
Aug 14, 2015 03:02 PM
Cam's maro
Aug 11, 2015 07:45 AM
