possible header leak, how to FIX??
Old Jun 29, 2003 | 11:49 AM
TMDZ28's Avatar
Question possible header leak, how to FIX??
how do you fix a header leak?? because my pass. side header is making noise while, my driver side header does not. do you think there's a leak. my pass. side header is making a raspy sounds. the more throttle, the louder the sound. how do fix this?? and will header leak decrease performance??? thanks a lot guys
Old Jun 29, 2003 | 11:24 PM
TMDZ28's Avatar
ttt
Old Jun 29, 2003 | 11:45 PM
Scream And Fly's Avatar
You should fix it right away for many reasons (too tired to list them now, but trust me on this one). Find out where the leak is coming from - you might get lucky and correct it by retorquing your header bolts. That's what I would do first.
Greg
Old Jun 30, 2003 | 01:43 AM
TMDZ28's Avatar
Greg
i'm having trouble doing that. i cant use my hand, since it will get hot as soon i start the engine. i planning to use a piece of paper to find it. do you have any tips?? thanks
Old Jun 30, 2003 | 08:07 AM
The paper thing is the best way to go, since hot headers are really painful to the touch. Before you even start the car though, make sure all of your header bolts are tight, then check your collector bolts. After that's done, then start the car and see if it still leaks. Oh yeah, make sure your fans are off when you're looking for the leak or the paper thing won't work as well!
Greg
Old Jun 30, 2003 | 08:15 AM
CANTONRACER's Avatar
Years ago when I was running shorties I had a bad header leak, or so I thought. I changed the gasket numerous times, the collector gasket, most every gasket that I could even remotely think it might have been.
I eventually went to LT's and after my shorties were off, I noticed that I somehow got a hole in the one that was causing me problems all along.
Old Jun 30, 2003 | 08:34 AM
Jim_H's Avatar
Will you lose mph in the quarter mile from header leaks? I would think no, but I am curious.
Old Jun 30, 2003 | 08:43 AM
Yes, and you can also burn exhaust valve(s) too if the leak(s) are large enough.
Greg
Old Jul 1, 2003 | 02:34 PM
TMDZ28's Avatar
Greg
darn......hopefully the leak is coming from the Y pipe connector.....
Old Jul 1, 2003 | 03:49 PM
Dave Feerst's Avatar
have you ever actually seen that happen? burt exhaust valves from header leaks. I mean I understand the theory behind it, but I was under the Impression youd have to pretty much run open heads to burn valves.
Old Jul 1, 2003 | 03:52 PM
RRios8191's Avatar
Header Leak
Try Motor Honey!!!
Old Jul 1, 2003 | 04:17 PM
TMDZ28's Avatar
Re: Header Leak
Originally posted by RRios8191
Try Motor Honey!!!
what?? i tighten all the bolts like 5 times after heat and cold cycle, i'm afraid it's coming from the Y pipe that connects to the pass. side header
Old Jul 4, 2003 | 11:02 AM
TMDZ28's Avatar
ttt
Old Jul 4, 2003 | 12:03 PM
95Blackhawk's Avatar
On my Hooker shorties, I had a leak and changed my header gasket twice, etc. etc. until one day I checked my EGR connection and what do you know...it was loose!
Just another thing for you to check, FYI.
Ben
Old Jul 4, 2003 | 12:10 PM
TMDZ28's Avatar
Ben
will do that.... thanks
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
alex5366
Feb 17, 2015 10:43 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
MislMan
Jul 19, 2002 11:41 AM
