possible cause for low idle?
Old Jul 30, 2003 | 09:24 PM
got_hp?'s Avatar
after installing my longtubes, plugs, wires, lt4km, pcmforless tune, and removed egr/air.............no my car is idling at about 600rpm...............i seem to remember it being like 700-900 before.............is this normal?
if not, what might it be?
Old Jul 30, 2003 | 09:32 PM
Acct 23749's Avatar
You may have a vacume leak...check all your tubes and stuff, make sure it all pluged in
Old Jul 30, 2003 | 09:37 PM
got_hp?'s Avatar
wouldnt a vaccume leak make the idle go up?
Old Jul 31, 2003 | 02:25 AM
Acct 23749's Avatar
Well when i think about it yes, but for some reason no, it doesn't work that way.
Go out to your car, or any car for that matter, and pull the brake vacume tube from the power brake booster, your car will almost die. When i do this it drops to about 500 rpms
600-700 rpms like your talking about may be one of the smaller vacume lines
just a thought, since you didn't mess with anything really, but in a header install this can happen
Old Jul 31, 2003 | 02:27 AM
Acct 23749's Avatar
also, how did you plug the EGR stuff? if its not sealed up perfect, it will do the same
Old Jul 31, 2003 | 06:42 AM
badblackz's Avatar
My money says you have a header leak before the o2 sensor. I had one after my install and had the same symptoms. When I fixed the leak I fixed my idle problems.
andrewcapps82
May 19, 2015 10:11 PM
Noenav
Apr 30, 2015 01:06 PM
edman
Mar 13, 2015 09:39 PM
camy 1993
Feb 3, 2015 06:26 PM
Hot Rod Hawk
Aug 15, 2002 10:47 PM
