Is it possible for a bad MAF make you lean out?
Old Jul 27, 2003 | 02:03 PM
TexasTechTA's Avatar
I dynoed and the AF was nearly 14.8 to 1 I think it could have been a bad maf is that possible?
Old Jul 27, 2003 | 02:06 PM
MattysTA's Avatar
have you had any pcm tuning done after the cam install? if not that would be the main reason why your so lean. if you have had tuning done then yes a bad maf could also make you run lean.
Old Jul 27, 2003 | 02:14 PM
madwolf did my tuning but I am leaning otu he did a great job fixing my idle problem I got a new maf and will see what is does when i get my opti fixed. also would bad igniton problem affect af ratio?
Old Jul 27, 2003 | 02:25 PM
atalay's Avatar
The perfect afr ratio is 14.7 to 1 and you are running 14.8 to 1. I don't see what the problem is. Your afr is around where it is supposed to be, unless you want your engine to run rich!!
Old Jul 27, 2003 | 02:33 PM
turbo_Z's Avatar
you are right during normal driving but i believe hes talking about WOT which should be around 12.5-12.8.
Old Jul 27, 2003 | 03:09 PM
ues I am talking at about wot it runs lean
DirtyDaveW
Dec 1, 2016 05:37 PM
grabbem88
Feb 13, 2015 03:09 PM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
