yet another head removal ?
Old Jul 27, 2003 | 12:29 PM
kcz28's Avatar
when removing heads do you have to remove the bolts that hold the rockers on?
Old Jul 27, 2003 | 01:32 PM
kcz28's Avatar
anyone have an answer
Old Jul 27, 2003 | 01:40 PM
Mr.Whitey's Avatar
You don't have to remove the rocker studs to get the heads off. All you have to do is remove the nut that holds the rocker onto the stud. The only reason to do that is to gain access to the head bolts.
Old Jul 27, 2003 | 01:42 PM
AsianSensation's Avatar
I removed the rockers before I removed the heads. I would sure hate for the valves to snap shut once the heads are off.
Edit-I missunderstood your question. I left the rocker studs on when I removed the heads. I thought you were talking about leaving the rockers on when removing the heads.
Old Jul 27, 2003 | 01:56 PM
kcz28's Avatar
I removed all the bolts except the banjo.
I was asking because they are not budging.
Old Jul 27, 2003 | 02:00 PM
Mr.Whitey's Avatar
Have fun w/ the banjo bolts. My new lines are coming soon. It was much easier to cut lines, remove bolt and order new ones. Some have cut the hard line and spliced in a flexible line.
What's not budging, the heads or the banjo bolts?
Old Jul 27, 2003 | 02:35 PM
kcz28's Avatar
the heads
Old Jul 27, 2003 | 02:44 PM
Mr.Whitey's Avatar
All I can tell you is to make sure that you have ALL of the bolts out and then try a rubber mallet. They may be stuck on pretty good.
Old Jul 27, 2003 | 03:11 PM
thewinner's Avatar
use a pry bar under the heads where they overlap over the lifter valley, use the front of the block to pry off of.
StansZ28
Feb 19, 2015 07:39 AM
chuyz28
Feb 19, 2015 12:50 AM
ModdedNerd
Jan 29, 2015 07:23 PM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
