ported intake question
Old Mar 18, 2012 | 11:35 AM
95impalaguy314's Avatar
Question ported intake question
i have a 95 impala ss. ive already modded the motor with a mid size cam from comp cams 1.52 rockers springs bbk headers custom 3 inch x pipe slp exhaust with cut outs granetelli maf sensor k&n cold air intake underdrive pulley 2400 stall. I'm planning on replacing the intake with a ported one and getting a 58mm TB. my question is can i make that swap without porting the heads or should i port and polish heads also?
Old Mar 18, 2012 | 01:35 PM
Re: ported intake question
Without a good set of ported heads, a 58mm throttle body is overkill. It's probably not necessary with anything under 450-500HP at the flywheel. Ditto with a "ported intake". The runners are about 3" long. There's not much to "port".
If you want to have your heads ported, get the intake ported by the same person.
Old Mar 18, 2012 | 03:39 PM
alright cool man i appreciate the help.
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
LT14LIFE
Feb 9, 2015 09:35 PM
MadMav
Feb 6, 2015 11:02 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
