Stuck 200 miles from home, alternator not generating power
Old Mar 17, 2012 | 08:20 PM
omega552003's Avatar
The alternator on my camaro flat lined after I floored it getting on to the freeway. The alternator works because its got over 500 miles on it and has been giving me 13.9v to 13.1v. I checked the excite circuit and it give me about 11.5v when battery is 11.8v. is it my instrument cluster since for some ****ed reason the alternator is controlled through it?
Old Mar 17, 2012 | 08:55 PM
Ocala93TA's Avatar
Re: Stuck 200 miles from home, alternator not generating power
I would recheck all your connections after a hard pull you may have knocked somthing loose . I have never heard of your dash having anything to do with your alternator charge , Where did you buy it? just because it only has 500 miles on it doesnt mean it wont go bad
Old Mar 17, 2012 | 09:37 PM
You say it has been giving you 13.x v, but what about now? Take a reading at the battery with engine running and not running.
Old Mar 17, 2012 | 10:42 PM
I did do some work earlier that required me to pull a grounding strap (it was put back on) that i need to double check.
As for the cluster, the excite signal comes from the cluster. i remember seeing how it works from shoebox.
Old Mar 18, 2012 | 10:27 AM
running its 11.7 not runnng 11.8, so im guessing bad alternator.
Old Mar 18, 2012 | 10:52 AM
Ocala93TA's Avatar
I would say that you found your problem alternator crapped out
Old Mar 18, 2012 | 12:30 PM
Got it checked at Advanced and it failed the voltage test. I'm a little shocked (no pun intended ) that the alternator crapped out after 3 weeks. got a new one and on my way home, hopefully this fixes my odd O2 readings i've been fighting.
Thanks guys!
Old Mar 18, 2012 | 04:03 PM
Reman alts are a crapshoot. Some last, some don't. The bad ones usually go quickly, though (like yours).
F'n1996Z28SS
Aug 23, 2023 11:19 PM
alphaauto
Jan 23, 2015 07:42 AM
mark0006
Dec 25, 2014 09:50 PM
XtremeLt1
Sep 13, 2002 08:50 PM
