View Poll Results: What is your oil pressure at hot idle and cruise rpm.
10psi-30psi
12.90%
20psi-40psi
58.06%
40psi-60psi
24.73%
60psi-80psi
4.30%
Voters: 93. You may not vote on this poll
Poll. What is your oil pressure?
Old Feb 6, 2005 | 09:43 AM
  #16
indieaz's Avatar
Re: Poll. What is your oil pressure?
I can't answer truly accurately - hot idle is around 25psi for me. At cruise it's around 45-50 .
Old Feb 6, 2005 | 10:52 AM
  #17
JB94's Avatar
I knew when I started this poll that there were going to be some people a little out of the posted ranges ,so if you want to vote just pick the one that fits the closest. Thanks to everyone who has voted and commented so far.
Old Feb 6, 2005 | 11:49 AM
  #18
GrdLockV6's Avatar
My previous two LT1's I owned had fairly low oil pressure. They were high mileage though. My current one has a high volume oil pump, and the engine only has 30k miles on it, so on this car the pressure rarely drops below 50psi.
Old Feb 6, 2005 | 02:06 PM
  #19
MTL_Z28's Avatar
These are exactly the readings I get as well. Warm idle is about 30 psi or 25 if I've been driving around for a while, but never drops below that. 45-50 psi when I'm cruising on the highway say at about 65 mph.
Old Feb 6, 2005 | 02:15 PM
  #20
TQdrivenws6's Avatar
Cold idle: 50psi
Hot idle: 38-40psi
Hot cruise: 50psi
Hot WOT: 60-70psi
Its a fresh 383 with a brand new stock GM pump, stock pressure spring, and 10w-40 oil.
Old Feb 6, 2005 | 05:22 PM
  #21
camzaro28's Avatar
once the car warms up, i idle around 15-20, and cruising speeds 35-40. i noticed someone said ealrier that when th ecar was stock they had more oil psi. same case here. i remember it never going under 45. now it always is under that, hevent paid attention undr full throttle. the car has 62k miles
Old Feb 7, 2005 | 01:50 PM
  #22
Deenasty's Avatar
ive got a high pressure oil pump, i get about 60psi at idle..
Old Feb 7, 2005 | 02:54 PM
  #23
TigerWoodsJr's Avatar
Its about 15-20 at hot idle and 39 at cruising...and MAYBE 40 at hot WOT, never more.
Old Feb 7, 2005 | 03:37 PM
  #24
WS Sick's Avatar
My motor is using a mellings stock replacement with the factory LT1 spring.
At idle warm it sets just above 25 and under the gas it tops 60.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
