Plz!! need quick help with Manual fan switch install
Old Jun 26, 2004 | 03:54 PM
battosai's Avatar
I have done all the mounting and ran the wires. All I have to do is splice into the wires on the PCM. My instruction from speedspeciality says to," Look at the appropriate connector on your car. There will be raised letters on the black part of the connector. Find (J) dark green and (H) dark blue." Well there are no raised letters. So does anyone know what the appropriate connector is? I have four connectors on my PCM. One is labled blue, one is labled grey, one is labled black and the other is labled red. And which wires are the (J) and (H) on the appropriate connector.
Old Jun 26, 2004 | 03:58 PM
RamAir95TA's Avatar
Re: Plz!! need quick help with Manual fan switch install
The raised letters are on the connectors on top of the passenger side fenderwell, between the PCM and the battery, to the left of the shock tower. There should be a wiring harness there with 2 or 3 connectors. Look at the connectors for the raised letters.
You are looking for the connectors in that harness, not the connectors on the PCM.
Old Jun 26, 2004 | 04:09 PM
battosai's Avatar
Ok I see what your talking about. Thanks a million RamAir95TA.
cristian1311
Nov 23, 2014 02:22 PM
Jul 4, 2005 05:00 PM
slothgrant
Aug 22, 2002 03:01 PM
x7x7
Aug 15, 2002 06:49 PM
sfGi8nt
Aug 1, 2002 05:54 AM
