plugs and plug wires
Old May 22, 2003 | 07:10 PM
zuluman13's Avatar
What plugs and plugwires should i get my plugwires are corroded on the inside so its time to change them and i decided to change my plugs as well.
Old May 22, 2003 | 07:13 PM
WheelmanZ28's Avatar
see sig
Old May 22, 2003 | 08:12 PM
Terran2k's Avatar
ac delco rapid fire plats and taylor 8mm wires
Old May 22, 2003 | 08:39 PM
jnco1xprez's Avatar
How about MSD 8MM wires? and Splitfire Triple?
Are the Taylor wires better than MSD?
and are the NGK better than Splitfire?
Old May 24, 2003 | 06:13 PM
zuluman13's Avatar
i also saw taylor has 10.4 mm plug wires is it worth the extra cost
Old May 24, 2003 | 06:42 PM
Derrick Redd's Avatar
I like the Accel Extreme 9000 wires. For plugs I'm using Autolite 103's, but that is for the 150-175 NX hit. For non-nitrous use you can go with a hotter heat range plug.
Old May 24, 2003 | 06:48 PM
96redformula7's Avatar
I just bought the taylor pro 8mm wires and the ngk tr55 plugs. I am going to put them in on Moday, Ill let you know, keep you up to date.
Old May 24, 2003 | 08:58 PM
95 Z/28 LT1's Avatar
Super Moderator
I really like Magnecor wires. They have a lifetime warranty and are made here in Michigan.
Old May 24, 2003 | 09:06 PM
FastZinTennessee's Avatar
Since I don't like changing plugs often I went with stock replacement platinums. They lasted for 100k miles, so put them in and forgetaboutit. Not sure about wires though. I bought some wires made by Taylor, 7mm I think. Pretty much stock replacement. I ended up burning one on a primary tube.
John
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
charchri4
Apr 14, 2015 06:40 PM
eanhl2004
Apr 4, 2015 12:01 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
gh0st
Sep 1, 2002 10:24 AM
