Plugs n' Wires: How much time?
Old May 30, 2010 | 02:48 PM
  #16
Dtimekw's Avatar
Originally Posted by FastandBlue
Yeah, first time on this engine, at least. I have all the tools necessary, I believe. I have a fairly extensive set of tools for engine work, so here's hoping. Was there anything special or out of the ordinary I need from this particular plug and wire change?
I plan on leaving the manifolds on, but does anyone else know if I need to take anything else off, or will I be able to get to it all without having to remove stuff? This is my primary concern above all else right now. Thanks!
I dropped the starter, made 6 & 8 much easier but then again, I have LTs. Manifolds might not be as bad. Either way, it's a pain but it's worth it!
Old May 30, 2010 | 04:38 PM
  #17
Mswezey's Avatar
From: Wichita Falls, Texas - College. DF-Dub, when not in college
Took me roughly 3 hours my first time, of course this was swapping out with my dad when I got to frustrated and back to me when he got to frustrated haha
Old May 31, 2010 | 02:39 AM
  #18
rbaksi's Avatar
Takes roughly forever. Its really difficult and frustrating. Have someone with skinny arms available to help you. I removed the alternator. I really hated doing it.
Old May 31, 2010 | 04:06 AM
  #19
FastandBlue's Avatar
Alright, cool. Thanks guys--I definitely appreciate it! Sounds like a job and a pain in the butt, but I'll get it done.
Old May 31, 2010 | 08:45 AM
  #20
ndpockets's Avatar
Plugs n wires
Hey post your time up here I have to do the same on mine, just bought it don't know if its every been done before. Thanks
Old May 31, 2010 | 11:12 AM
  #21
Will do, but probably not until later this week. They still have to come in.
Old May 31, 2010 | 10:04 PM
  #22
CheshireCat's Avatar
On my 94, I found it easier to drop the exhaust y-pipe and cat to give me extra room to move when getting some of the plugs from under the car.
I've done almost all of the work on my 94 since I bought it, and plugs and wires may have been the most frustrating job I've done. I don't think I'd even try to get oversized wires in the stock looms on the passenger side.
Good thing they don't have to be changed very often...
Old May 31, 2010 | 10:14 PM
  #23
Hmm, kk. Have you done the motor mounts or starter? I'd say those two top my list as the most frustrating. How do they compare?
Old May 31, 2010 | 10:36 PM
  #24
If you have the stock Y-pipe on the stock cast iron manifolds, you will almost certainly break off most of the studs if you try and drop the Y-pipe. Then you will have another frustrating problem.
Old May 31, 2010 | 10:53 PM
  #25
Lol, EXACTLY why I am not going to do that! I'll do it another way. I already tried dropping thy Y, but I quickly discovered it would be a long process.
Old Jun 1, 2010 | 12:24 PM
  #26
I haven't done the motor mounts, but have replaced the starter. The starter was also much easier to do with the y pipe removed... Plugs and wires were WAY more frustrating to me... Partially because changing plugs and wires on most cars is so easy...
I've read about that being a common problem, but I didn't have any trouble backing the nuts off the studs. I did pre-soak them with pb blaster. and hit the threads with a wire brush before I tried to remove the nuts.
If I was ever going to do headers, that would have been the time to do them...
As a side question, to the original poster... Do you have any reason to think your plugs and or wires are bad? (arching, missing, etc...)
Old Jun 1, 2010 | 12:28 PM
  #27
bw_hunter's Avatar
https://www.camaroz28.com/forums/sho...d.php?t=746143
Old Jun 1, 2010 | 03:30 PM
  #28
ditto. But thanks for checking! These wires are pretty worn man, so I figure I better just replace them now. Not only are their cracks all over in them, there's some metal exposed, too. Not good.
Old Jun 1, 2010 | 05:51 PM
  #29
bombebomb's Avatar
All day and then some, took us all after noon to get all of them out but one, we left it in till the next day we noticed we had been so frustrated we never tried a non deep well on it. Second time (few days later, don't ask) my step dad managed to do all the plugs in and out in a little over an hour.
Old Jun 1, 2010 | 06:04 PM
  #30
Oh that hurts. Ok, well I will probably wait until I get back to my place in western washington until I change the plug wires. How much can you honestly mess up your engine by driving with a misfire?
