plug wires used in place of Delteq?
Old Jul 5, 2005 | 09:52 AM
flusz28's Avatar
what wires have you guys used to replace the delteq wires since i have heard alot of issues with them. i suck at making my own wires, so i would like to find wires that are long enough to use and 8mm.. thanks
Old Jul 5, 2005 | 10:04 AM
1quikZ's Avatar
Re: plug wires used in place of Delteq?
If you want 8 mm use Talyor pn 76030, But i like to run 8.8mm and I think most do, I use ACCEL 300+ 8.8m pn 7137. Part numbers are from www.summitracing.com
Old Jul 5, 2005 | 10:12 AM
flusz28's Avatar
8.8mm is cool with me. now sine i have my headers wrapped should i have to worry bout any heat issue with the plug wires? do i need sleeves for the wires?
Old Jul 5, 2005 | 10:15 AM
flusz28's Avatar
also these are long enough for hte valve cover coil mount? i have the four coil setup (northstar) thanks again
Old Jul 5, 2005 | 11:16 AM
sbs's Avatar
sbs
What issues have you heard?
NM. I just reached the other thread down below.
Old Jul 5, 2005 | 02:03 PM
ZBLKHELLRZR's Avatar
Taylor 10.4mm. I like overkill.
Old Apr 12, 2006 | 01:16 PM
Black_95Formula's Avatar
Ditto on the Taylor 10.4mm wires... Nice and fat.
Old Apr 12, 2006 | 03:41 PM
Type_O_Negative_1320's Avatar
I used a set of Accel wires (8.8mm)...here's a link to my post about them.
http://web.camaross.com/forums/showthread.php?t=379894
They've been on the car for almost a year so far...I drive it ~20 miles per day. No problems whatsoever.
EDIT: Crap, didn't see that you have your coils mounted on your valve cover. My coils are mounted under the fan.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
