Plug Wires?
Old Nov 5, 2006 | 03:57 PM
Mystic95_Z's Avatar
Plug Wires?
I need to upgrade my plugs and wires, I have NGK TR-55's already ordered. I was wondering if I need a OVC setup w/longtubes or if I bough others could I route them someway to keep them from burning? I have read about alot of people having problems with the OVC setup.
I dont really like the look of the OVC setup but If i have to go that way I will.
What brands of Wires would you suggest if I dont need the OVC...
Old Nov 5, 2006 | 04:13 PM
Bersaglieri's Avatar
MSD 8.5mm Super Conductors. You can run the many ways without going OVC. In my opinion that looks like total garbage in an engine bay, and I care very little about the way things look.
-Dustin-
Old Nov 5, 2006 | 04:19 PM
2000GTP's Avatar
You can keep your stock routing, but you will have to go through some extra measures to prevent the wires from touching and burning on the header primaries. You will have to secure the wires safely away from the header with cable ties. As for the actual wires, I would give another vote for the MSDs or the Taylors.
Old Nov 5, 2006 | 08:05 PM
1FstFormulaV8's Avatar
I had mt TR55's and MSD S/C 8.5's installed. I would have went with the OVC route if I had headers. I'm still using my manifolds, and I knew if I went with OVC's I'de burn them up. The MSD plug wires are quite large. The right side is the worst to route. There's practically no clearance on that side. It's totally up to you.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
