Please help my car hates me!!!
Old Oct 24, 2004 | 09:29 PM
got8?'s Avatar
Ok i just replaced the Fuel pump filter Maf plugs wires. The car starts fine but its shakes and shakes realy bad when i put it in gear. When i drive it it is exremely slow and unbearable under 2k but gets a little better over 2k. If i give the car too much gas it will stall out when it comes off the line please help me i have had this problem for about a month now!!!
Old Oct 24, 2004 | 09:36 PM
turbo_Z's Avatar
Re: Please help my car hates me!!!
So did you replace those parts to fix the problem you have now or did you pick it up after the work?
Old Oct 24, 2004 | 09:44 PM
got8?'s Avatar
Well it all started after i changed my plugs and wires then i thought taht i might have a wire criss crossed but it wasnt so thats when it all started butthen i replaced the fuel pump and the mass air i am so sick of this car breaking all the time
Old Oct 24, 2004 | 09:58 PM
n2ceptor's Avatar
Ran OK before wires and plug change, then after it runs rough....Hhhhmmmmmm
Check wire connections, are the wires pushed in all the way???
Are plugs gapped a .050???
What kind of spark plugs used?? Are they the right plug???
Are the spark plugs tight and didnt come loose?????
Old Oct 24, 2004 | 10:00 PM
got8?'s Avatar
yep i checked it like 30 times every thing is set up right i used bosh platinums
95_LT1_6SPD's Avatar
I had a similar problem. Turns out one of the boots on the plug end of the wire was loose and not getting spark. The wire looked fine, until you kinda tugged on the end a bit. Just pushed it back in and now it works fine.
Old Oct 24, 2004 | 10:14 PM
n2ceptor's Avatar
Where the plugs one of these #... If so, you can cancel out wrong plug...
HR8DCX SUPER PLUG Gap=.050 Locate Retailer
HR8DPX PLATINUM PLUG Gap=.050 Locate Retailer
4205 PLATINUM PART Gap=.050 Locate Retailer
7571 SUPER PART OE Plug is Platinum; Gap=.050 Locate Retailer
4305 PLATINUM2 Do not Gap Locate Retailer
4458 PLATINUM+4 Do not Gap Locate Retailer
Old Oct 24, 2004 | 10:53 PM
CamaroSS30thAnn's Avatar
i hear about ppl having similar problems with Bosh platnum spark plugs, hope u get ur problem fixed bud ttyl
Old Nov 1, 2004 | 07:30 PM
jsz28's Avatar
Turned out that got8 had two wires criss crossed.
LastChance719
Dec 3, 2014 07:55 PM
USAirman93
Nov 24, 2014 03:37 PM
regular Joe
Aug 10, 2002 07:15 PM
regular Joe
Aug 8, 2002 03:47 PM
regular Joe
Aug 8, 2002 07:53 AM
