Please help me with some OBDII codes
Old Feb 26, 2004 | 08:05 PM
5H9D0W's Avatar
Exclamation Please help me with some OBDII codes
P0171: Oxygen Sensor System Too Lean Fault Bank A
P0507: Idle Speed Control Engine Speed High Fault
I need to get this fixed soon cause there gonna suspend my plates pretty soon.Any advice would be nice. Mike
Old Feb 27, 2004 | 05:17 PM
5H9D0W's Avatar
anyone?
Old Feb 27, 2004 | 05:59 PM
5H9D0W's Avatar
I've been researching my problem and have come to the conclusion that my IAC is bad.What components sum it up.How would I be able to trobuleshoot an answer.I have a 58mm bbk Tb.Does this change anything&tb bypass free mod. Mike
Old Feb 28, 2004 | 12:12 AM
P0507 is idle system high, IAC responding. Sounds like you may have the 58mm TB idle stop screw adjusted incorrectly. What RPM does it idle at? Apparently it is significantly higher than the stock PCM setting of 550rpm in gear and 650rpm in neutral.
P0171 is fuel trim lean, drivers side. Apparently the long term fuel corrections on the drivers side have max'd out at 160, and are unable to control what the PCM sees as a "lean" condition. Typical causes include exhaust leaks before the O2 sensors, misfires, and faulty O2 sensor/wiring.
It would probably be helpful if you could put a scanner on it and check the IAC counts and TPS voltage at idle to try and sort out the P0507. Then log some data while driving and look at which cells the long term fuel corrections are max'd out (or at least verify that they are max'd out).
Jeff'SS
Jun 1, 2015 06:21 AM
BIGRIG
Parts Wanted
Apr 28, 2015 07:56 AM
aj2494
Mar 12, 2015 10:17 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
