Window Switch Wire, where does it GO???
Old Feb 27, 2004 | 11:55 PM
roadtrip120's Avatar
I have a MSD Window switch but i dont know what wire to tap into at the pcm.
It's on a 97 T/A m6,
I thought it was the Red wire harness on pcm with the white wire, which should have been A13, but i read a post and it said A25???
I tested both but the voltage was constant threw out the RPM.
What wire do i tie into, for the msd window switch to work, that reads the tach/ RPMs??
Old Feb 28, 2004 | 12:02 AM
13 is the tach wire (white).
25 is the fuel enable wire and would be dark blue.
Old Feb 28, 2004 | 12:03 AM
I tested the voltage on 13 and it was constant, around 4.9
Old Feb 28, 2004 | 12:24 AM
I have not had to test the wire myself, but I know that it is the correct wire for the tach by all wiring diagrams (same in OBD-I and II). It may actually be a rapid pulse that the tach uses and not as easily read with a volt meter-not sure.
Old Feb 28, 2004 | 12:27 AM
Thats all i needed to know, thanks
Keenan
Jan 19, 2023 12:24 PM
Heathen1
Jan 2, 2016 04:27 PM
mattstrike
Mar 11, 2015 07:33 PM
warmeck
Feb 2, 2015 12:44 AM
x7x7
Aug 15, 2002 06:49 PM
