Please help me identify this coolant hose (pics)
Old May 2, 2006 | 11:45 AM
Rising Phoenix's Avatar
One of the coolant hoses that connects to the waterpump on my Firebird cracked open while I was driving it this morning. I'm not sure what the hose is called or where I can get it. It's on the passenger side of the water pump.
Pic 1
Pic 2
Can anyone tell me what this hose is/what it's called? I know it's one of the heater hoses; can the small piece from the water pump to the metal coupler thing be replaced or does the entire hose from front to back need to be replaced?
Also any part #'s if you have them would be appreciated
Old May 2, 2006 | 12:01 PM
94EvilZ28's Avatar
Re: Please help me identify this coolant hose (pics)
The metal piece is just a clamp...you can reuse it...
Old May 2, 2006 | 12:31 PM
Javier97Z28's Avatar
Moderator
He means the part below the clamp...
That hose has a restrictor fitting in it, but Im not sure that it can be separated from it. You might be able to get away with splicing and putting in a new piece of hose there.
I'm not sure how the car reacts w/o the restrictor..
Old May 2, 2006 | 12:38 PM
Sparkz28ss's Avatar
my goodyear kit does not have that restrictor fitting ....and its fine
Old May 2, 2006 | 12:55 PM
Dave Holland's Avatar
Hose goes to the heater core. I would try and splice it if the remaining hose isn't dead. Otherwise you'll need to get a new line which includes the metal piping if you want to replace it with what's there. The restrictor slows coolant flow through the heater core. Your heat may not work as well if you replace the line with plain ol' hose, but it may not matter depending on where you live.
Old May 2, 2006 | 01:19 PM
Sparkz28ss's Avatar
yeah....Im in texas....so I use my heater like once in a blue moon
Old May 2, 2006 | 01:49 PM
Always a good idea to check Shoebox's Tech Pages:
http://shbox.com/1/heater_hoses.jpg
http://shbox.com/1/95-97_hoses.jpg
Old May 2, 2006 | 02:26 PM
Mtrhds94Z's Avatar
that is a 3/4" elbow that you can probably get in a parts store, and then cut that lower swaged fitting off, and just replace it with regular worm type hose clamps.. cut the aluminum clamp part way thru [make a slit]carefully with a Dremel etc and use a big screwdriver in the slit and twist to finish breaking the clamp
I am sure i have seen small elbows like that in parts stores...
If not shoebox has the GM p/n, it's hose # 7 on the diagram
Old May 2, 2006 | 02:32 PM
Mtrhds94Z's Avatar
Interesting comment since the GoodYear kit doesn't include the restrictor to hard pipe hose at all, just the 3/4 elbow..[unless they 'reengineered' it.. which last I checked, they hadn't]
About 2 years ago I went around with GoodYear engineers about the missing piece[the kit has 10 of the 11 needed hoses]they promised to include the 'missing hose' in future kits, but never did..
Can you verify that the 11th piece is included now? and that the 3/4" elbow ISN'T included?
Thanks!
Charlie
Jlo
Feb 3, 2015 09:41 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
pologreen97z
Dec 2, 2014 10:42 AM
cristian1311
Nov 23, 2014 02:22 PM
Sixer-Bird
34
Aug 31, 2002 12:59 PM
