can you replace opti ?
Old May 2, 2006 | 02:25 PM
dallas63's Avatar
can you replace opti on 1996 z28 with something else .
Old May 2, 2006 | 02:35 PM
Re: can you replace opti ?
Not easilly. You have several choices for upgrading it though.
Replacement Opti:
-OEM GM
-Summit (available, and the first failure has been posted)
-Accel (just getting into people's hands)
-MSD (not in production yet)
-Dynaspark (about 4 years of history on this one, but never sold well because of high cost)
Remove high voltage section from Opti:
-Delteq (4-coil pack from Northstar engines)
-LTCC (8-coil setup using LSx coils)
-aftermarket ECU capable of accepting Otpi optical sensor signals and driving an external high voltage section)
Do a "search" on any of the above key words and you should find a lot of posts
Total Relacement:
-Electromotive Opti Eliminator/Super Direct Ignition - there were about 20 of these units built... worked OK with batch fire 93's, so-so with sequential fire OBD-I 94-95's, and caused problems with codes on the OBD-II 96-97 LT1's. I had one for a while, but gave up on it and went with an aftermarket ECU, using the Opti pulse signals and an external driver for 8 LS1-style coils in direct fire. Proven faultless over a period of 6 years.
grabbem88
Mar 18, 2015 01:25 PM
maybe2fast
Mar 16, 2015 11:59 AM
grabbem88
Parts Wanted
Mar 8, 2015 04:08 PM
Alex Barnes
Jan 24, 2015 10:21 PM
pologreen97z
Dec 2, 2014 10:42 AM
