Please help, I'm carless it won't start!!
Old Mar 11, 2004 | 03:15 AM
bdc95ta's Avatar
well I go to try and start my car (95 ta) and as soon as I turn the key from the on position to the start position it sounded like a faint pop or maybe I was hearing things it's really late and I'm fairly tired. Anyways the lights flashed and then nothing. Darkness the clock wouldn't turn on, the doors wouldn't lock. No flashing lights on the speedo when I turn the key back to the on position. It's late so I can't see very well but all the fuses looked ok to me. I replaced the one I have my electric wp going to because I assummed it was that. But no luck I'm going to go back to IHOP tomorrow after work with an ohm meter. I really need my car though guys I can only bum rides for so long. Any helps greatly appreciated.
-b
Old Mar 11, 2004 | 05:14 AM
slopokrodrigez's Avatar
Sounds as though the battery is low, bad or has a bad connection. First thing to do is check battery voltage. Then with the key on, check the battery voltage. Then with the key in the crank position, have someone check the battery voltage. You don't want the voltage to go much below 11 volts when cranking the engine.
If all that checks out, you want to clean all the connections. Be sure to get not just the battery terminals, but the positive cluster on the passenger fender and especially the grounds to both the engine and the frame. These 2 grounds are almost never checked or cleaned.
Old Mar 11, 2004 | 03:55 PM
bdc95ta's Avatar
anymore suggestions guys I'm going to get off work in an hour and a half
Old Mar 11, 2004 | 04:11 PM
Jeremy_30th's Avatar
ignition fuse...
Old Mar 11, 2004 | 04:22 PM
bdc95ta's Avatar
which fuse is the ignition fuse????
Old Mar 11, 2004 | 04:57 PM
97Camaro007's Avatar
sounds like a low battery to me also....i don't think a fuse would fix it unless it is all of them that is blown.....
Old Mar 11, 2004 | 10:13 PM
bdc95ta's Avatar
this is weird. I checked all the fuses w/ a meter and w/ close inspection they were all good. So I checked the battery w/ the meter good also my mom was w/ me and she swore it was the battery also so I got it checked at autozone and there machine said it was good too. Then I took off the alt. to take to autozone and hooked back up the battery. And all the lights and radio, door locks everything worked again. It was getting dark, and the cars still stuck up at IHOP, so I didn't reinstall the alt. and crank it. I had bible study that I was late too so I'll get the alt. checked tomorrow morning at autozone. Then see what it does from there. There was just a very little bit of corrosion on the + connection nothing that would be of much restriction but I'll scrape that off tomorrow morning too.
My lights, doors nothing worked before now everything seems to work power wise:
The only thing that I did diff. was
1) remove my electric wp from the fuse panel
2) I have a racetronix fuel pump and I didn't reinstall the chassis ground to - battery terminal wire.
3) Removed my starter kill.
? could one of these things be the cause of my problems??????
OR IS IT JUST THOSE DARN GRIMLINS!!!!
Old Mar 11, 2004 | 10:21 PM
Probably a poor connection that you "fixed" when messing with stuff. If you found any corrosion, get rid of it.
Old Mar 11, 2004 | 10:31 PM
bdc95ta's Avatar
thanks shoebox your the man!
Old Mar 12, 2004 | 04:02 PM
bdc95ta's Avatar
Well I finally got a ride and took my disconnected alternater to autozone. It wasn't holding a charge what should I do??
1)Buy a autozone remanufactured one for 75-80 bucks??
2)Buy a new autozone for 175 bucks.
3)Buy one from Mr. Cromer.
4)Buy one from the internet.
I have underdrive pullys should I get one w/ a little more amps to help out on idleing????
Old Mar 12, 2004 | 05:06 PM
bdc95ta's Avatar
I have no prob. buying a new alt. expecually if it's going to save me all that hastle. Should I buy one from autozone or somewhere else?
Old Mar 12, 2004 | 05:13 PM
jakesnake123957's Avatar
i got mine from oreilly auto parts 189 dollars,its still good,oh yeah make sure your batt cables are not corroded,it hides up under those red or black plastic covers>Jake
Old Mar 12, 2004 | 06:57 PM
bdc95ta's Avatar
hey jake how long have you had it for?
eazyZ
Mar 1, 2015 07:12 AM
Scottyboy
Feb 11, 2015 10:28 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
