Please help with electrical problem
Old Nov 3, 2005 | 07:37 AM
charlezd71's Avatar
Unhappy Please help with electrical problem
My 94z keeps blowing the accessoy fuse about two minutes after I replace it. It just started doing one day, I was not doing any electrical work on it at all. All the dash lights and gauges work fine its just the dome lights when I open the door and the trunk switch is connected to that fuse too. I have replaced the door pin switches to no avail. Please help Its scary being in the dark.
Old Nov 3, 2005 | 07:56 AM
Re: Please help with electrical problem
Are you sure it is not the courtesy fuse? The accessory fuse has nothing to do with the interior lights. Sounds like you have a short you need to track down. It could even be something in the radio (if it is actually the courtesy fuse).
Old Nov 3, 2005 | 08:13 AM
Welcome to CamaroZ28.com
You already have this topic on "General F-Body Tech & Info".... PLEASE post a topic only once, on the correct forum.
liamcg97
Nov 25, 2019 05:55 PM
eanhl2004
Apr 4, 2015 12:01 PM
robcarnut
Mar 20, 2015 03:40 PM
BMX Dad
Jan 23, 2015 07:00 PM
97z28k&N
Jan 9, 2015 04:58 AM
