1.6 rocker help
Old Mar 9, 2005 | 08:48 AM
jaredwayt's Avatar
1.6 rocker help
i want to run a set of 1.6 rockers on a stock heads/cam car but i need help with a couple of things.
-if i run self aligning rockers, would you suggest running with some comp 7/16 studs or are the stock ones fine?i will be running lt4 springs,retainers, and locks.
-if i run nsa rockers what afe the pros/cons of these rockers?what else would i need to run nsa's?
thanks.
Old Mar 9, 2005 | 09:15 AM
Bud M's Avatar
Re: 1.6 rocker help
For nsa rockers you will need guideplates. GM p/n 14011051.
7/16 studs are not necessary but if you can spare the extra cost, why not?
Old Mar 9, 2005 | 09:20 AM
jaredwayt's Avatar
Re: 1.6 rocker help
i finally found some stuff from the search, and i think im going with stock rocker studs, and probally some SA rockers, but has there ever been a proven hp advantage over sa to nsa's, i heard that they are more reliable, but is there a hp advantadge with the nsa's???
Old Mar 9, 2005 | 09:31 AM
rocmemphis's Avatar
Re: 1.6 rocker help
I would go ahead and get some ARP hardened studs. I actually broke 2 or 3 of the stock studs when I installed 1.6 rockers and valve springs.
Old Mar 9, 2005 | 09:34 AM
1racerdude's Avatar
Re: 1.6 rocker help
No!!
Old Mar 9, 2005 | 09:43 AM
jaredwayt's Avatar
Re: 1.6 rocker help
kool!!
Old Mar 9, 2005 | 11:33 AM
RE AND CHERYL's Avatar
Re: 1.6 rocker help
I would replace the spring as you would be pushing the stock springs to the absolute limit. A little abuse and you could easily break or fatigue a spring.
Old Mar 9, 2005 | 12:13 PM
jaredwayt's Avatar
Re: 1.6 rocker help
i am im using lt4 springs retainers and locks
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
MDZ28
11
Sep 24, 2015 09:15 AM
