Plastic valve covers need modding for pro mags?
Old Nov 4, 2005 | 12:33 AM
jmzlt1's Avatar
Question Plastic valve covers need modding for pro mags?
Hi guys. I know that the stock steel valve covers need to be modded for the pro mag rockers, but what about the corvette composite/plastic valve covers? Do the pro mags fit with no problem, or is some grinding neccesary? Thanks in advance.
Old Nov 4, 2005 | 12:37 AM
DavesLT1's Avatar
Re: Plastic valve covers need modding for pro mags?
are you talking about the LT4 composite valve covers? those shouldn't need mods as they were designed to clear the 1.6 RR's anyway.
Old Nov 4, 2005 | 12:55 AM
jmzlt1's Avatar
Yes, but their designed to clear narrow body roller rockers like the gm or Cranes. I'm going to be using 1.6 pro magnum rollers with a 7/16 stud. I'm wondering if there's going to rub or hit anywhere.
Old Nov 4, 2005 | 01:03 AM
Jon A's Avatar
No modding required.
Old Nov 4, 2005 | 01:05 AM
Transamdriver's Avatar
http://web.camaross.com/forums/showt...t4+valve+cover
Good info in that thread.
Old Nov 4, 2005 | 08:50 AM
sssalah's Avatar
The pro magnum rockers have interferance issues with the supports on stock valve covers. The composite covers don't have these support, I'm running them with 1.6 pro mags and 7/16" studs.
Old Nov 4, 2005 | 12:19 PM
DavesLT1's Avatar
yeah, they'll run fine. in fact I read a few times here people are running the Scorpion 1.7 RR's and use those valve covers because they cut down on noise and don't need to be modded.
Old Nov 4, 2005 | 01:06 PM
Dan Parker '96's Avatar
I'm running CompCams ProMags 1.6's with the stock covers ('96 Vette). No problems.
Old Nov 4, 2005 | 03:07 PM
wrd1972's Avatar
Are you talking about the bone stock LT1 plastic covers from the 93-96 Corvettes?
Old Nov 5, 2005 | 12:09 AM
jmzlt1's Avatar
Thanks for the info guys.
Old Nov 5, 2005 | 06:52 AM
Bone-stock '96 covers. I think the '93-'95 need some drip tabs clipped to clear.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Roadie
Feb 16, 2015 10:34 AM
HectorM52
Jan 30, 2015 11:34 PM
Caps94ZODG
Sep 7, 2002 10:09 PM
