Placing Intake Manifold back
Old Mar 17, 2004 | 08:52 PM
Grebas94Z28's Avatar
I have a question before I go and put the intake manifold back on. Just got it off tonight. I got the permatex "right stuff" for the gasket in the front and back of the Manifold. I also bought the Fel-pro 1284 gaskets, the ones a little better than stock. They came with some black rtv. Should I use this rtv on the gaskets or something else? and where should I put it? Both sides of gaskets just around intake ports? is that good enough or use more? I will also need to get a throttle body gasket, stock one for GM dealer? or is there a better one? what size tube to connect the hoses for the throttle body bypass if anyone knows? I have a temporary piece of pipe connecting them now, but need something that will be permanent. Thanks for any input.
Old Mar 17, 2004 | 09:49 PM
ZDriver96's Avatar
Best stuff for the gasket is the GM grey sealant.. Forget the exact name but the dealer sells the stuff.
Either one of those sealants u have is fine though. I ended up using felpro gaskets and only put red RTV infront and back of the intake manifold. any tb gasket is fine.
go to discount auto. they have a TB bypass on the shelf for 5 bucks or something
Old Mar 17, 2004 | 10:50 PM
ledfootz28's Avatar
yea i have some of that grey stuff.u can get it at the dealer,its good stuff when i took off my timing cover i ripped the right corner and i just sealed it with that.but for the intake man repair i just used some black rtv,i heard its better than the red to keep oil in.
Old Mar 17, 2004 | 11:23 PM
96z's Avatar
96z
I used ultra copper after messing around with an intake leak last spring. No problems since.
Old Mar 18, 2004 | 06:36 AM
Thanks for the input. Which auto stores have the TB bypass? I will check out the local store. I guess there are more than just our cars that have this throttle body coolant passing through it that are the same size?
Old Mar 18, 2004 | 11:47 AM
slashz28's Avatar
the hose youre talking about plugs right into the crossover tube on the pass. side of the manifold. size?? if i recall correctly, 1/4" maybe?? somewhere there though. hth
Old Mar 18, 2004 | 12:28 PM
You need a 3/8" barbed hose connector for the 93/94 TB bypass.
Old Mar 18, 2004 | 08:36 PM
thanks for the input injineer, will go to find one of those. Yes I am talking about that hose which goes to the crossover and that through the TB
DirtyDaveW
Dec 1, 2016 05:37 PM
ModdedNerd
Dec 14, 2014 10:28 AM
Elcojoe
Nov 17, 2014 10:27 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
